Clawhammer
I've been thinking about cobbling together some sort of a power bank, possibly solar powered or possibly not, to take camping and to take to music festival (assuming those ever happen again). All I really want to do with it is run some lights at night, charge cell phones and laptops, and maybe run a fan or a radio.
Currently I'm thinking about just picking up a cheaper deep-cycle battery (like from a golf cart or a trolling motor), and housing it in a tool box with a Harbor Freight inverter like this one: Cheap Inverter Depending on how fast it would drain, I could just charge it up at home off an outlet, take it camping, then bring it home to recharge. If I could snag one cheap enough, I'd think about picking up a solar panel to keep the battery topped up. My longest trips are usually a week to two weeks, so I'm not sure it would be necessary though.
I guess that brings me to my questions. There's just sooooooo much info online that it gets overwhelming and the next thing you know, you've tallied up several hundred if not thousands of dollars worth of stuff you "need." Since I don't plan on running a fridge or anything major, and only plan to use this a few weeks here and there, I want to have as little invested in a power bank as possible (but still have it be, at least somewhat, reliable).
So basically, if you were setting out with the needs I've listed above in mind, what would you buy? How big of battery and how big of an inverter? Would it be worth investing in a solar panel too, or is my home charging plan enough juice? Harbor Freight also has a cheap solar regulator I was looking at it. Obviously, the panel would have to be sized right for the battery which is whole 'nother ball of confusion... Anyway, if any of you could steer me in the right direction, I'd sure appreciate it!
