Extended brake lines - F550
Srpat
I am looking for some help finding extended brake lines for the front of my 2012 F550. I bought some off of Amazon from Rough Country. Not quite the right fitting to attach to the hard line. It looked like it might work if I took it apart to try and also if I fabbed a new bracket to hold the hard brake line in place. I contacted KLM Performance, who was one of the only places I found searching to see if they could custom make a brake line or if they sold one. They make extended brake lines for Ford trucks and make custom brake lines, but apparently, only for the 2014 and up F550s. Anybody know where I can go? 41" tires and a 2" lift has the factory lines a little stretched when articulated.
Srpat
You might check crownperfomance.com
The F250/350 lines seem to be what I need for the front. The connection from the hard brake line to the SS brake line is a square with the hard brake line coming in from the side. But, when I asked KLM performance about it, they seemed to give me the impression that it wouldn't fit and that I needed custom lines that they couldn't make for my 2012 F550. So does anybody have any idea if that would work? I just assumed the front ends were all the same from F250 to F550.
oskarf150
