6x4 Truck
ocairo
Hi, I would like to know if you think that a 6x4 truck (VW, Mercedes Benz, etc.) can work to build an expedition truck or a global expedition unit. The reason I would go for the 6x4 truck is the cost, but I'm not sure if it can work well and hence the question. All the best, Osvaldo
quickfarms
Make shore you get lockers in each axle and an air locked power divider.
Run floats on the front axle
You should not have an issue as long as you stay away from deep sand and mud
shortbus4x4
This right here. It's amazing what a 6x4 will do running duals with everything locked up.
oskarf150
