Yes I plan to daily drive it and drive to far away locations. I want at least 33s AT tires because if I keep the 32s I don’t see much reason to get the Bronco with a ground clearance inferior to a Subaru. So do you think there is a significant difference for street driving between 33 and 35 and if yes which ones?
If you don't think the Bronco offers anything over a Subaru if the base ground clearance is similar then I think you need to do more research and get some more experience under your belt.  They are wildly different vehicles with very different capabilities, base ground clearance is just one spec and doesn't say anything about the capabilities of the vehicle itself.
35s are going to be louder, heavier (more unsprung weight is going to affect ride and handling), have a large impact on fuel economy, won't be as stable in corners or when there are high crosswinds.  The Sasquatch is a great package if you're going to wheel locally and daily drive it, but road trips are likely to be annoying.
It is a hard decision, though, because it comes with more than just 35" tires.  If there were a Sasquatch Jr package that offered 33s instead then I think that would be a great all-around option.  Of course, you could just downgrade to 33s if you decide you don't like how the 35s perform on the street/highway.
Ultimately up to you, I've just been around long enough and seen enough people buy rigs that are much more capable than than the driver's skill level and that has gotten them into a lot of trouble.  I find it's more beneficial for inexperienced drivers to start out with a vehicle closer to their skill level so they can understand both the limits of themselves as well as their vehicle and then they can grow together, making mods that are necessary based on the limit that has been reached.  I wouldn't put a teenager in a Ferrari and I wouldn't put someone new to off-roading in one of the top-spec factory off-road vehicles and send them on their way, either.  Not saying that's you, just saying that's kind of how you came across.  I know it's hard to resist buying the most capable vehicle you can right off the bat so you can be "prepared for anything" but being prepared is actually more about driver skill than the vehicle itself.
Good luck with whatever you choose!
