Portable diesel heater by Expedition Upfitter
Victorian
We are getting a lot of requests about our portable planar diesel heaters and thought it’s time to give you a full run down video. easy to order through www.expeditionupfitter.com ( accessory sister company of total composites)
Herbie
Rendezvous Conspirator
So no recirculation, correct? (We heat outside air and pump it via the hot-air ducting to the living space.)
Something like this makes sense for those of us who only need heat seasonally or on extended travel. The hard part for me, of course, would be to create an interface to the living space. I have a "tilt out" window that I could possibly create an insert to fill the gap with a duct/plenum, but it'd be non-trivial.
Josh41
FYI. I made a DIY version of this last winter with an Amazon cheap version of the heater using kerosene. It felt like it made sense to heat the outside air and pipe it in. The heater was capable of heating cold air (I tested in the teens (Fahrenheit) with no problem heating the air) but here is the catch, the fresh air to be heated (not the combustion air) would suck in the exhaust gasses and then send that into the camper. This was a solid no go for me.
Superduty
Did you have an "exhaust pipe" to direct the the exhaust away from the fresh air?
Or maybe pull the fresh air from father away.
Seems like a problem that could be fixed.
Sent from my SM-G973U using Tapatalk
Victorian
You could easily pump the hot air through a window.
Herbie
Our side glass is the hinged at the top tilt-out variety, so we'd need to fill the whole wedge shape between the glass and body. (Or use the front window.)
Man
Why did you pick yellow for the case color? I'm a big fan of colors that blend while out in the wild.
JaSAn
Grumpy Old Man
Kind of expensive.
I am planning on using one like this:
- note the exhaust pipe (and muffler); could get extra to make it longer.
And either route it through the rear left corner where an internal heater exhaust would exit.
- That would require cutting a 2" hole and finding a fitting that I could plug when not in use.
or​
make a plywood cover for inside the rear jelousie window, replacing the screen.
- plywood would cover the whole window from the inside, so no drafts when window is open.
- easier than trying to seal around the open window.
Victorian
The are being purchased in bulk.. the decision was made a long time ago. Yellow was the most appealing.
Victorian
Kind of expensive.
or​
You can, of course, purchase wherever and what ever you want. You either go cheap and get what you pay for or you spend more for quality that includes a direct line to outstanding customer service and spare parts if needed.
AeroNautiCal
Planar diesel air heaters are the best of the type, with a proven reputation for quality, reliability and longevity.
To be able to buy one professionally configured to operate from its own stand alone case hugely increases its practicality, versatility and desirability!
