Ford F250 17-19 crew cab - Rhino Rack Pioneer Platform
Taken off a 2019 F250 crew cab after I traded it in. I used this for a iKamper rooftop tent as shown in below pic.
Details:
For install you would need the following as they weren't re-usable after initial and removal per
8 x M5 x20mm socket head cap screw PN B028
8 x M5 spring washer
8 x M5 x 10mm flat washer PN W027
8 x Butyl patch 20mm x 20mm PN CA1266
1 x M8 channel nut PN N003-BLK
I assume you can call up Rhino Rack to get those spare parts.
Price $600 (paid $1250 last year)
Local Pick up Denver, CO
Knobbyman
Did you have to drill new holes or did the spines use the holes already in the roof?
Once you removed it, can you tell that it was once there?
No new holes it uses the existing bolts so going back to stock is no problem. I removed it when I sold the truck.
iStan814
