Title kinda says it already. Me and my partner are still searching for and thinking of what would be the right vehicle for longer-term travel, but in considering a van we've been wondering how to manage insulation. Due to my length we would have to install a bed lengthwise, and we want a fixed bed, so that doesn't leave too much living space. As the van would be intended for full-time living, we would want to install swivel seats. We are living quite far up North, just yesterday had -40 degrees (we're in Europe and apparently that's the point where Celcius and Fahrenheit numbers become equivalent, ha). We also like traveling around here, and are interested in eventually shipping the van and also spending time further up North in US/CA, among other places. Now, -40 is not an everyday thing and more on the extreme end, would primarily try to just avoid such temperatures when living out of a van, but it would be nice to be able to be comfortable in let's say up to -10 to -20 degrees Fahrenheit.
So yeah as mentioned we're planning for cold weather use, we'll install a diesel heater and possibly an additional electric heater (connect to external power or from the engine). Now if it weren't for the swivel seats it would be ideal to have a closed off cab to make things a lot easier, but alas. Covering the windows is an obvious thing to do, but doesn't get the same effect at all. We currently own a different van, also without separate cab, and it's not uncommon to get ice on the inside of the windows in the front even when covered. Additionally there clearly is some kind of draft, one place I know it runs is where you put your feet while seated in the front seats, and it's an older van meaning I don't believe everything is sealed off very well. Either way, my concern is with the cab space being the hardest to insulate and the biggest source of heat loss when not separated from the living/sleeping space, quite unpractical when designing for winter use, and I'm wondering how to mitigate this somehow. Couldn't think of much myself aside from covering the windows. One other idea is some type of heavy curtain inbetween the swivel seats and the dashboard/windows/doors, but that'd have to reach to the floor, thereby get dirty quickly, and probably get in the way much. Seems like a not-so-ideal solution, but maybe some clever variation of this? Any folks here have some experience with swivel seats + cold weather insulation, or ideas in general? And also, does anyone have insight into how much heat is lost through the front doors, seeing how they're usually made of some separate material and not insulateable in the same way as the rest of the vehicle, if at all?
Greetings from cold places
