ProwlerDriver
12v in the back for maybe a fridge... or the Joolca water pump. Still debating on how far to go with a rear buildout.
	Thinking the same for my 100. Maybe a multi vehicle order to excite Eric?I am digging the build. I have reached out to Eric at points about doing a pop top. It is high on the list for future mods on my 100 series. Maybe I could ask a few questions now that you have some miles on the build. Is the wind noise at speed any worse than before? Any additional squeaks or rattles from the pop top? Does it feel like it changed the rigidity of the body when you are in tougher obstacles off road?
As for awnings, one of my favorite awnings I have found so far is the Equipt 2000. It is lighter in weight and it has a spring loaded retracting system for the awning material that makes it super easy to put away. I presently have the Shadow Awn. I probably wouldn't do it again. It is heavy so it can be tough to unmount and the weight is up high. It also isn't height adjustable because it doesn't use poles. Is if the rain is coming in sideways I cannot adjust the angle of the awning at all. Plus the price is quite high.
For a tent, I would go with something with the easy up style that is available now. It makes it a breeze to put up and saves a lot of time. Looks like the RV5 is that. I have thought about one of the Gazelle tents just because they are inexpensive. Plus they are popular so reselling would be easy if I don't like it.
	Can you share any info on how you mounted the roof rack? Are you using Front Runner hardware, or did you piece something together yourself?
Ooops, just saw your note. Let's talk c858-273-5809Well, you need to let me know then. I’m looking too for a pop up or other possibility to make the back more functional.
Bump for contact......Ooops, just saw your note. Let's talk c858-273-5809
