D
		Deleted member 9101
Guest
Personally, I'd replace everything with LEDs. Your alternator doesn't put out much power to begin with and adding extra lights and accessories will necessitate more power.
That is my plan once I get around to new tires, crank the torsion bar up a bit to level it with the back, new tires, and an alignment. I was also thinking about shocks from one of the models you mentioned. I am trying to research parts compatibility on things like thatYou should be able to crank up the torsion bars a bit to level it out,
Just don't go overboard and top out the suspension.
Rodeo, Early Trooper and Passports share quite a few parts for up grades.
Try to keep it as light as possible.
I did run through the auto carwash and cleaned the truck up a bit, but it is going to need a good scrub to get some of the layers of dirt off, especially the buildup on the wheels.
Good point, I hadn't thought too much about that. Once I get the bed rack in I will give that a shot and see how it looks. I will probably just need to leave a little more of a gap between the back of the cab and the cargo box to access the lock and open the box, but that wouldn't be a big dealcool little truck, I would love to find something similar for adventures.
Just a thought, would turning that cargo box around net better aero for trips? Having the sloped edge to the rear would help make a tailing affect and since the cab is in front of the box you wouldn't need to worry about creating drag building up air pressure putting the flat side forward.
excited to see how this progresses
Thanks for the tip on Rockauto, I will take a look at that for parts compatibility!Back in the day I ran Rancho RS5000 shocks on trucks like this with good results.
Do you know that if you look up a part on Rockauto when you click on the PN it will give an interchange
for what vehicles that part also fits. Handy feature
Thanks for the recommendation, headlight upgrade is definitely coming in the near futureI put Hella H4 E-Codes in my '83. Cannot even describe how much I love them. So much better than the old sealed beams.
