Flooded vs, AGM vs Li comparison - interesting but not objective I think
OllieChristopher
It's an interesting read but as you say not objective. The tests were not done over years of abuse. Granted I don't have all the fancy test equipment but I can tell you LiFePO4 batteries are getting better all the time. I'm coming up and 9 years and hundreds of hours of the hardest abuse you can imagine on mine. I will "discharge abuse it" over and over until the BMS shuts the battery down.
I also do not buy into the detrimental effects of cold charging a LiFePO4 battery. Even at freezing temps you can simply power up devices to warm the battery so it will charge safely.
Bang for the buck I am of the opinion that AGM batteries are still a tried and true option for those on a budget.
john61ct
LOL fast charging an LFP bank when well below freezing temps can render a 20,000 investment instant scrap dead as a doornail.
How anyone "feels" about that fact is irrelevant, and it's very easy to test if you really doubt it.
Now milder temps and slower rates, you might only be losing a few hundred cycles per incident iff the back end, might not notice for 15 years, so yes hard to get data, lots of variables involved.
LFP as a generic chemistry is only "getting better" in two senses
1. manufacturers have been improving energy density (not power density)
2. we now know better how to treat them in order to get 8-10,000 cycles before SoH hits 75-80%
The problem compared to 15years ago, is that the list of proven top notch quality cell makers has hardly expanded, but there are hundreds of "cheap Chinese" vendors selling via eBay and Ali, and then all the so-called "drop ins" and powerpacks where no one know what the cells are like, often not user replaceable, so have to assume 2-3000 cycles is best case scenario.
Bang for the buck in lead, so long as you are buying true deep cycle units
by far is FLA.
Unless you really need the higher C-rates, or mounting on their side or something.
The best lead battery value by far is Duracell (actually Deka/East Penn) FLA deep cycle golf cart batteries, 2x6V, around $200 per 200+AH @12V pair from BatteriesPlus or Sam's Club. NAPA relabels it here: https://www.napaonline.com/en/p/NBP8144 Deka self-labeled also sold at Lowes.
The only good AGM for true deep cycling usage is Odyssey, Northstar and Lifeline
with some special use cases justifying Firefly Oasis.
But the cost per Ah per year is at least 2-3x the Deka's.
john61ct
RTFA feedback.
Yes lead batteries are 99.99% of the time grossly "optimistic" in their Ah capacity ratings.
Even if you do your precisely timed CC load cap test at slower than the standard 0.05C (20-hr rate)
And of course the actual capacity you measure at commissioning time (after break-in period)
will be sharply declining each quarter if you repeat the benchmark,
so your 50% guideline is also dropping in absolute Ah.
In the LFP world, good cell manufacturers in the pouch and especially prismatic universes
routinely deliver 5-15% **greater** Ah capacity than the nameplate.
This is not a major factor in all those taken into account in comparing the chemistries.
Especially in a market where LFP costs 5-10x as much per usable Ah.
john61ct
The measure of a good lead battery is **not** how accurate their nameplate ratings are
but how slowly SoH% declines per say 100 cycles, the total lifespan before hitting 75-80%.
Compared to the price per actual usable Ah of course.
As stated above the EPM GC's are the king of the NA market in that regard.
john61ct
It is not correct that Wh should be used for capacity.
So long as the nominal voltage is in the same ballpark (e.g. not comparing 12V to 24V)
Ah give a much more accurate and usable representation of "energy quantity" in and out when dealing with batteries, any DC storage/ discharge system really.
john61ct
Lifetime cost per sable Ah **per year** would only be lower for LFP f you were doing 100+ deep cycles per year
ideal for those fulltiming off grid for decades.
And **only** if nothing happened to reduce lifespan, even with BMS protection "stuff happens." 10+ years to get ROI is silly risky.
There are **lots** of good reasons to go LFP
but purely economic calculations really go the other way.
john61ct
Waiting 24 hours or more to get accurate resting voltage is actually done **all the time** in lab condition testing.
But is not necessary to get "good enough" SoC data points, an accurate shunt based coulomb counter can be used, but you need to get the Peukert coefficient and CEF sorted first.
In reality just going from the very precise and objectively defined 100% point, to an LV cutoff calibrated for your chosen CC discharge C-rate
is all you need to benchmark actual useful capacity at that rate.
john61ct
As to "objectivity" there of course is no "one best" battery.
Too many owner- and use-case specific real life variables involved.
For someone only cycling say under 80 nights per year off grid and not a wealthy person showing off they have all the latest tech
Those Deka FLA GCs just cannot be beat for value.
If you **really** want sealed, then it will cost you, but likely only a couple hundred or so more per year.
If you just **can't** treat them properly so you only get a few years out of them maybe a bit more,
really better off with the cheapest - but still true deep cycle - at ~$1 / Ah@12V
If you are meticulous with proper care then Rolls Surrette FLA can last 14+ years in daily use, and that's without the LFP complications.
OllieChristopher
Yes John, The X2Power (rebranded Northstar) are the ones I'm thinking on getting for my dual battery setup:
The 5 year replacement warranty is a good selling point. And the distributer is just a few miles from me.
I originally was going to go with a couple of Optima Yellow Tops. But the Amp hour rating is a little less. I'm just a little shaky using that brand as I'm of the belief the longevity is not quite up to par with some of the other offerings. And the warranty is only three years.
15 years ago I would have not batted an eye and went with Optima hands down. A lot of the off road racers still use them as they are super durable and impervious to vibration and shaking.
john61ct
Yes Odyssey / Enersys originally brought that spiral TPPL technology to the NA market, and under their strict testing & production QA, Optima was a super product, suitable for true deep cycling.
Then they sold the line to JCI (Johnson)
meh. Just like Sears Diehard!
Still fine for a robust Starter though, even support occasional winching etc.
But not true deep cycling anymore, hardly anything sold in automotive or big box retail channels is
99.99% fraudulently labeled all, shame there is no standards body or gov Consumer Protection to enforce objective standards
whole industry is dominated by scammers throughout
OllieChristopher
That's just about for anything we buy these days. When I was younger you had only a few choices of any giving product. These days you have to sift through a bunch of bad to find the good.
My favorite kind of reviews are the long term testing ones using math. What makes being objective difficult is tests like the one above. I'm pretty confident at some point we are going to get really close to perpetual motion as far as energy is concerned.
DirtWhiskey
Western Dirt Rat
Well I'm no battery expert and some of the stuff you're talking about sounds like a different language, so please take this with a grain of salt. I've burned up dozens of SLA and AGM over the years (probably because of above), but I will for sure be doing Lifepo4 for my camper build this year. The advantages of not dealing with absorption charge, high amp alternator charging (the biggest advantage IMHO), deep discharge ability, light weight and no need for venting are too much to overlook. I don't really camp all that much in really cold weather but the temp issues seem easy to overcome.
john61ct
Yes so long as well protected against all the possible murderous "events"
despite costing 6-10x more than lead up front, it is "possible" to work out cheaper over say 20 years use
especially if cycled very frequently.
But that math, requiring decades before getting ROI is **not** persuasive.
The reasons you cite are the main ones.
An energy source at high enough amps can supply days' worth, even a whole week, in just a couple hours
And no need to ever get near 100% SoC
Those are the two big ones.
The low temp issue has several solutions, easiest being make modular packs and just take them with you when the living space you're leaving will be dropping down to freezing while you're gone.
Of course the biggest to pro's for LFP are that the owner loves learning new electrikery tinkering as a hobby, and
the joy of bragging rights, being on the bleeding edge.
Ancientsojourners
