NMO mount for ARB bullbar
Owyhee
ICU Nurse, Shepherd, Father.
Can anyone suggest an NMO mount that will feed through the hole on the upper Tabs of an ARB bullbar. It's the winch bar for a 1996 FJ80 Land Cruiser.
73 KJ7PVH
Owyhee
I think this may work I need to check the thickness, as this one is only good out to 1/8" and I may have to bore out the opening to accommodate 3/4".
My intent is to run signalstuff's new automotive antenna.
dstock
There's an NMO thick plate mount that's also the correct diameter so you dont have to drill your bumper. I have 3 of them. Let me find you a link.
Sent from my Pixel 3 XL using Tapatalk
BigSwede
The Credible Hulk
I don't think the tabs are 3/16 thick, if it is anything like the ARB bullbar I had on my old Trooper. The hole will be too small for standard NMO mounts but maybe those linked above will work.
Joseph McCormack
