SOLD! 2017 Kenworth/GXV Patagonia 4X4
Daurie
After much thought we have decided to sell our truck. It has served us well during the few times a year we get to enjoy it. We recently moved and are (thankfully) working more than usual. That being the case have decided that now is the time to pass it on to someone who has the time to get the most out of it while it's still in practically new condition. I personally have meticulously cared for and maintained the truck. It's been serviced at intervals far more frequently than the factory recommendations. The generator hasn't been run long enough to be ready for it's first service mostly because there is plenty of solar to keep the batteries up and utilize the truck comfortably barring any extreme heat conditions when you may need to run the A/C for extended periods. We always saw anywhere between 40-55 amps incoming with reasonable sun. Comes with all spare filters and multiples of some. After initial break in only Rotella synthetic was used. Listed below are the details I copied from our original purchase.
Don't hesitate to ask anything.
Truck details and things I have added:
2017 ( not put into service until July 2018) Kenworth K370
12000 lb front axle (this was the factory axle and I believe the 4wd axle has a higher rating but I don't have the spec)
Adjustable front air springs for tuning ride. These are in addition to the leaf springs and are adjustable from the cab.
21000 lb factory LOCKING rear axle
Factory rear Hendrickson air ride rear suspension with air dump (comes standard on truck and useful for leveling in some situations)
King truck shocks at all corners
Manual locking/unlocking front hubs
Ti Systems inflation system at all 4 wheels (this is not CTIS)
Paccar PX7 engine rated at 250HP/660 ft lb
2 factory 45 gal saddle tanks and 1 100 gal aluminum tank with permanent plumbed in transfer pump between the frame rails. Pump controlled via sPod in cab.
4 wheel drive installed by Tulsa Truck
Air brakes front and rear with secondary ARB twin compressor plumbed into air dryer.
Dual Odyssey 2150 chassis batteries
sPod Bantam in cab and 8 circuit Source in battery compartment with touchscreen for both
Baja Designs perimeter/rear/ditch lighting
Baja Designs 50" light bar
Front and rear winch
Truck will cruise comfortably at 70 between destinations, under normal conditions. I usually keep it around 65/68 as the tires are rated to 68 mph and when I get out I'm not in that big of a hurry.
(I will add more as I remember!)
PATAGONIA EXPEDITION BODY
GXV Structural Composite Sandwich Panel Construction Expedition Body, Color: White
Body Length: 17' 6" (5.3m) ● Body Width: 96" (2.4m)
Interior Height: 6' 7" (2m)
Cab to Cabin Access
Rear of Expedition Body squared off for maximum storage capacity
Main Entry Door with 3-point Stainless Steel Lock system
Lowered Entry Door coupled with electric step & motion-sensor LED light above door
Premium Armor Vision Dual-Paned Glass Windows with integrated Blind and Insect Screens
Locations: Kitchen, Dining Booth, Bed area-2. Qty 4
Rear-Spare Tire Mount, manual operation
2 Rear Aluminum Storage Boxes with slanted bottom, Black Powdercoat, 46" length (1168mm)
--Hydronic system & gray water installed in driver side box
KITCHEN / GALLEY
Cabinetry Package: Laminate finish on plywood
Corian Countertops
Cabinet Doors and Drawers equipped with positive latch closures
Stainless Steel Sink, single bowl, with Single Lever Faucet
Cooktop Dual Burner Induction
Refrigerator/Freezer: Vitrifrigo, Marine-Grade Stainless Steel, 2-Drawer Style
Microwave / Convection Oven, Stainless Steel
Armor Vision window
2-120v outlets in Kitchen area
BlendTec Under-counter SS Blender
DINING AREA
Front Dining Booth with adjustable Table, converts into auxiliary sleeping area 2-Armor Vision windows
1-120v outlet and 2-USB outlets in dining area
BEDROOM, located at rear of Patagonia
Queen size bed, 60" x 80" (1524mm x 2032mm)
Headboard with storage and Charging Station: 2-120v outlets and 2-USB 2-Armor Vision Windows
Upper Cabinets on L&R side wall, above Windows
LED Reading Light
WASH ROOM, located forward of bed-drivers side Wet Bath with Shower, Toilet and Sink
Teak Lower Cabinet with Stainless Steel Sink Teak Medicine Cabinet with Mirror
Thetford Cassette Toilet 1-GFI 120v outlet
WASHER / DRYER CABINET
Floor-to-Ceiling Cabinet to house Washer/Dryer and Microwave Splendide #2100XC Combination Washer/Dryer
Drawer at bottom of cabinet
Washer/Dryer installed above lower drawer
Microwave installed above Washer/Dryer
CLOTHES CLOSET
located between bath & washer/dryer Floor-to-Ceiling Cabinet to house Washer/Dryer and Microwave
Hanging Rod above, shelves below
AUDIO / VISUAL
Kenwood Audio Head Unit, CD/DVD/Blue Tooth, Satellite Ready Sound Bar
Jensen LED 12v HDTV, 26", on adjustable Wall Mount
ELECTRICAL
Mastervolt Electrical System - World Leader in mobile electrical systems Marine Grade Wiring and Sealed Connectors Throughout
12v with 120v Systems, Consisting of Shore Power Inlet and Interior Outlets Mastervolt Easy View Systems Management and Monitoring
Mastervolt Mass Combi, 12/2500w-100 Inverter / Charger
Mastervolt MPPT Solar Charge Controller
Mastervolt Lithium-ion 375ah Batteries, Qty 2
Generator Onan QD 3200w, Diesel, Auto-Start
5ea Solar Panels, 200w. Total 1000w
Energy Efficient LED Lighting throughout. Dimmer at bed area
CLIMATE CONTROL
Webasto® Hydronic Thermo PRO 90 Coolant Heater variable from 6,100 Btu to 26,000 Btu. Provides thermostatically controlled forced air cabin heat, domestic hot water, engine-off heating, and preheats engine in cold weather
7-Day Programmable Timer
Air Conditioning, High Capacity Rooftop Unit with Wall Thermostat Exhaust Fan • High velocity, with rain & temperature sensors
PLUMBING
Fresh Water Supply, 135 gallons (510 liter)
Water Pump: Variable Speed, 4.5 gpm (17 liter)
Gray Water Poly Tank, thermally protected from freezing, 28 gallon (106 liter) PEX Water Piping Installed Within Cabin Envelope
2017 | 25k Miles | $465K
Currently Located in Horseshoe Bend, Idaho
jlcanterbury
This thing is amazing!
Seems like a great deal compared to the other Kenworth rig listed on Expo right now (with an unfinished box for $800k).
Great looking vehicle, good lick with sale!
Wakeup2river
Can you list the details of the engine, drive train, suspension and any other mechanical like you did the other areas of the vehicle?
gdaut
Wow that is nice. Looks like you also have a front winch from the pictures. Cannot tell about the rear. But, you might want to add that to your description.
Daurie
Thanks for that. There is a front and rear winch which I added to the description.
