Upgrading Alternator to charge house batteries faster
IdaSHO
IDACAMPER
And just how "critical" is terribly relative. Hard, perfect numbers on paper are one thing.
Real life is another. Real life shows that the VAST majority of users WILL NOT perfectly maintain their batteries.
That's a fact. So Ill take my $300 in batteries every 6 years and keep driving.
Simple numbers show that I spend roughly $4 per month on batteries.
To bring things back to earth and into perspective....
Most on this forum will spend more than that PER DAY on their morning coffee. :ROFLMAO:
BobInTheAspens
Optima says that there is no limit to how fast you can charge their batteries, assuming that the voltage is OK. They say 13.6v to 15.0v. That means that even with a fairly small battery, the limitation will always be your alternator and wiring.
My 2008 4runner has a 130 amp stock alternator. At idle, will charge my 2nd battery (a 50 AmpHour Optima) at 75 amps for a few minutes, and then drop to 60, 50, 40, as it gets charged. If your vehicle won't charge at that rate at idle, check your charge voltage. Most vehicles are set to a much too low voltage.
Buy a Xantrex LinkLite. It monitors charge and discharge amps at the battery very accurately, and will give you the percent level of charge in the battery quite accurately. At about $200 it is very worthwhile. Otherwise, you are just guessing.
The wire that carries the charge from the alternator to the battery will never overheat. The reason is that as amps go up, voltage goes down, and the battery will accept less charge. That is a fail-safe situation as far as safety goes. Of course, you want to make the wire fat enough to not reduce your charge rate too much.
john61ct
100% false.
Even if theirs is the highest CAR lead battery on the planet, the trailing amps bottleneck is always there with lead.
Say you do an A / B test both with a 75Ah battery depleted all the way, i.e. to 50% SoC.
Even if that battery can in theory pull 500A in that state, it will only do so for a few minutes, then increased ESIR as SoC climbs will start to drastically reduce the current rate.
This is true no matter the voltage setpoint.
A on an alternator capable of putting out 50A continuously
B at 200A
B might get to the CC-CV transition point after only 50min, while A takes 90min.
But A may be at 80% SoC when it does so, while B only 70%.
And as current acceptance drops to say 20A over the next 3-4 hours, they both end up at similar say 92 vs 95% Full
those last few SoC% still takes another 2-3 hours
At 1A flow, that is still 0.013C even if at 98% might still have an hour to go
100% Full does not happen until current drops well below half an amp.
B might reach that say 30min earlier than A, but still over 6 hours.
Every lead bank **must** get to that 100% point very regularly for decent longevity, ideally "most cycles", certainly at least once a week.
Firefly Oasis being the sole exception, but that's a separate thread.
And since Optima really is just a decent Starter since bought out by JCI,
no longer actually built good enough to use for deep cycling
all this is a moot issue anyway.
