New to forum RRS
thewarhammer
Have a 2009 RRS and just found this forum. Bought the truck about 3 years ago and have been messing with it ever since. Has some pretty cool stuff done.
*A TON of maintenance
*OEM G4 light guards
*OEM G4 ladder
*OEM roof racks
*OEM Mud flaps
*OEM side steps
*ASFIR rear differential guard
*ARB full on board air
*Nitto Terra Grappler 265-50-20
*IID tool for diagnostics and height changes
*Roam Awning
*Maxtraxx traction boards
Also have a hidden winch that will be going on soon! Just figured I’d say what’s up!
gabrielef
*OEM G4 ladder
*OEM roof racks
*Roam Awning
Welcome! That’s a nice rig! I run with an ‘06 LR3. What region are you in? There should be some good Rover groups around.
thewarhammer
Thanks fellas!
Im in NYC but to be honest, I don't know many people around with Rovers. Would definitely like to check some groups out.
btkummerer
New here myself but finally building out my '07 RRS to do some light overlanding. Nice rig!
Curious, what did you use for a lift or have you not got into that yet? Looking at the Johnson Rods and Proud Rhino kits and cant seem to find a difference. Also curious as to how much trimming is involved.
thewarhammer
Hey thanks man. Good luck with the build! There is a lot more out there for these things than I realized.
As far as lift rods, I actually used IID tool to adjust it through the ECU. All lift rods will essentially do the same thing but I got what I needed out of the software and it is a must have for a Rover. No trimming should be required unless you start getting to 32"+ tires.
project13support
