Victorian
Ready for you to outfit to your taste and budget .
This trailer gives you the same qualities as our bigger expedition trucks without the price tag or maintenance costs! Enough room for a nice seating area , wet bath and kitchen. Full standing height!
Build by total composites in Victoria bc to the same standards and high quality as their expedition trucks. Sold as an empty shell so you can outfit to your taste and budget. No matter the climate, you will be comfortable inside with its super insulated walls. There will be guaranteed NO condensation or water leaks as seen with regular cheaply build trailers. Total weight as it sits is only 550kg/ 1000lb . Check out our website and see about the quality and impressive differences to regular travel trailers.
Trailer specs:
True 4 season capabilities
Rugged construction for off road adventures
Sold as empty shell, mounted on flatbed trailer
Customer can outfit to their liking, taste and budget.
Easily demountable if needed
1 year warranty on materials and craftsmanship
Dimensions:
Overall length 197" / 5000mm
Overall width 82.5" / 2100mm
Overall height 106" / 2700mm
Interior length 135" / 3430mm
Interior width 78" / 1980mm
Interior height 78" / 1980mm
Trailer chassis features:
GVRW 3500lbs
All aluminum construction (made in Canada)
LED lighting all around
Solid axle with leaf springs
Tires Sumitomo Encounter AT 31" X 10.5R 15LT 109R
Stabilizer jacks all around
Aluminum wheel wells (insulated)
Assembled Camper body:
Total Composites foam core panels and extrusions
Thermal transfer free
R 12 insulated
2" / 50mm foam core panels all around
Outside FRP skin is the extremely impact resistant, woven structure gloss white
Inside FRP skin is smooth gloss white
All corners are stainless steel for added protection
Travel trailer highlights
** Skylight 500mm X 500mm with integrated LED lights, bug screen and sunshade
** Two exterior windows 450mm X 1100mm by Arctic Tern
Entry door 22"/600mm wide X 63" / 1600mm tall Thermal transfer free, insulated (Made in Germany)
Panorama hatch 58"/1470mm wide X 42"/1060mm tall Thermal transfer free, insulated (Made in Germany)
price: cad$ 28,000
Trailer specs:
Dimensions:
GVRW 3500lbs
R 12 insulated
price: cad$ 28,000
