SOLD - 2013 Jeep JKU, Ultimate Dana 60s, 22,500 miles, $35,750 OBRO
daviscb
This Jeep is located in Utah north of Salt Lake City. Built for overland travel and backcountry exploration. Why am I selling? Since moving back to Utah I finished this build, built a house and shop, put in the yard and now building a cabin. I haven't used this as much as planned only putting on 4,000 easy miles since upgrades were completed. I don't see this changing in the near future and don't want to see it sitting in my shop. It has always been stored inside.
Upgrades include:
Suspension
Spicer Ultimate Dana 60 Front and Rear Axles, 4:88 Ratio, will accommodate 37" tires.
Adams Driveshafts, Front and Rear, 1350 CV Joints
Mopar Brake Cables
E-Lockers Front and Rear
AEV 2.5” Spring Kit
AEV Suspension Hardware
AEV 2.5” Bilstein Shocks
AEV Bump Stop Spacer Kit
Currie Control Arms with Johnny Joints
Grade 8 Suspension Bolt Kit
Rock Krawler Adjustable Swaybar Links (Front Disconnect)
Synergy High Steer HD Drag Link
Synergy HD Chromoly Tie Rod
Synergy HD Rear Track Bar
Brakes
Mopar Upgraded Brake Booster
Spicer Ultimate Dana 60 Front and Rear Brakeline Kit
Wheels / Tires
(5) Cooper Discoverer AT3 LT285/75R18 (35”)
(5) 18” Alloy Wheels
Other
Receiver Hitch with Wiring Harness
Complete Set Poison Spyder Steel Crusher Flares (In Box)
Poison Spyder front Inner Fenders (In Box)
Rear Storage Shelf
Floor Liner Kit
Rear storage shelf
Rhino Rack Backbone System
Prinsu-type custom roof rack, Aluminum and Stainless Steel Hardware
Synergy Front and Rear Grab Handles
AEV Frame-mounted Tire Carrier
S-Pod 6 Switch System
AEV Procal Module
Will consider reasonable offers. No trades please. Thanks for looking.
daviscb
For those less familiar with these upgrades, the axles are designed and built by Spicer specifically for the Jeep JK Wrangler. They include brakes and other components from the 1 ton Dodge trucks. The brake booster and brake cables come from the Jeep J8 military model. All other upgrades are designed and built specifically for the JK Wrangler.
Emac
I see e lockers, are they Eaton electric lockers ? Or Detroit easy lockers?
What transfer case dose it have and is it a 4 to 1 low range?
I am interested , Ed
daviscb
These are the Eaton lockers that come in the Spicer Ultimate Dana 60 axles. The transfer case is the stock transfer case, not 4:1 in low range. My experience is 4:1 is too low for overlanding and more for rock crawler. Let me know if you have any other questions. Thanks.
Emac
661 802 3214 if you have a few minutes, thanks Ed
V45W_Proto2.5
