Victorian
the 6.5' camper was allowed to leave the shop today ;-) Still waiting for the windows but as far as prototyping goes we seen and figured out what we needed. Loving it!
			Noted thanksJust want to chime in and say, I really think you guys should make one for the 5.5 foot bed (F150 / 1500 etc). It is a very popular bed size and nothing exists for it. I know the 5 foot one will fit, but it is likely not taking full advantage of the width between wheel wells and also misses out on an extra 6 inches.
Thank you
Cab over depth is 48" . Although the 8' is a lot bigger than the 5' (mostly due to weight consideration for smaller trucks) fitting a bath is still tricky (but possible) The door will be centred as a standard, sadly, can't change that.These look amazing! I really see the potential for a wet bath on the 6.5' if the entry door is offset to the left or right.
What is the length of the cabover? I noticed you mentioned you will be posting the CAD for these soon. I'm looking forward to it.
Ah, are you cutting the door openings at manufacturing in China?
The honeycomb frp panels you used on your van are inspiration for a lightweight wet bath/wet entrance.
Real world weights:
the 5' camper is 230kg/530lb
6.5' camper is 336kg/745lb
8' camper is 350kg/780lb
This weekend we are placing them in as many trucks as possible!
Overland Adventure Truck in Olympia has started taking pre orders. The order book is filling up fast for California, Oregon and WA
Tacoma test fit went well.
Are the 6.5 & 8’ campers wider than the 5.5’? I assume that explains the weight difference.
I really need the dimensions/CAD before I can place an order. Any movement there?
