Does anyone know of a compatible 12v cig -> Jackery adapter?
socceronly
I tried contacting Jackery, but heard nothing back. They don't seem to sell them.
Mine vanished on me.... :(
This is for the Jackery 1000
I can't see any specs on it on their site.
Thanks
JM
John Shaffer
To do what, charge it? The specs appear to be 12 to 30 volts.
I think it's just an 8mm coax, same as what Goal Zero uses.
https://www.amazon.com/SolarEnz-Connector-Cigarette-Portable-Generator/dp/B08G555CNY
The Explorer 1000 also accepts PowerPole connectors on its input, so you could use this:
https://powerwerx.com/cigarette-lighter-powerpole-adapter-18in
Hi
I’d suggest making one. Get a good 15-20a cig barrel with a 30-45amp Anderson PP on the end and put in between a APP 130v meter to an APP to 8mm cable. Best suggestion. That’s what I’ve done for my Bluetti. All my cables are APP mixes.
In this picture (1) I’m running 10ga from my dual battery to a powerwerx panel mount with 45a connectors. As you can see I have a meter in between for testing connected to a 12ga 45a cig to APP adapter.
For reference is a 8mm to APP cable as a adapter for various APP uses.
Next is the Bestek 300w inverter connected to the cig adapter connected to the AC/DC brick.
If you notice my Bluetti it’s charging at 86w. Best performance with the OEM. If I was to try this without the inverter it would not provide enough 12v power to charge. Hence a waste of time.
I have a Lenovo AC/DC that gets hot but will push up to 112w that’s possible @ 10-11A
Good luck.
seth.c96
