Hallmark Milner MX 2004 with new composite roof for 6.5 bed - $12,500 (bent HECO lift arms need replacing)
bryant3155
- New Composite roof with new thermal insulated soft walls (windows all have bug screens)
- 2 fantastic fans
- 60 x 80” Queen size bed with plentiful storage underneath
- 30 gallon fresh water tank + 3 gallon in hot water tank
- Hot Water Heater
- Outdoor shower
- 20lb propane tank
- 2 x 6volt NPP 225AH AGM batteries (replaced this year 2021)
- Dometic 3 way fridge
- Atwood forced air heat furnace
- 3 burner stove
- Dinette / Bed 39 x 74” (fits large pack and play)
- LED lighting
- 4 jacks
- Mounting hardware included (fits first gen Tundra’s, might fit others too not sure).
- New 60 watt solar with charge controller
Work Done this year:
- Replaced high pressure propane lines and regulator
- Replaced fan and electric board in the Atwood furnace
- New thermostat for heat
- 2 new AGM 6volt batteries (these things hold charge for a very long time)
- new 60 watt portable solar panel with charge controller
The good - aside from the roof damage described below this camper is in pristine condition. I’m the second owner, purchased it from the Hallmark dealership in Denver as a trade in they had in January of this year. They went over it before leaving to make sure everything was in working order (pictured). We’ve camped at Wolf Creek pass in a snowstorm in this and stayed completely warm. We’ve mostly used it as a ski camp setup as we just had a baby so it’s been great to keep our kid warm while parents go play.
The bad - last week I lowered the roof after using it but forgot to latch the roof down, drove down the highway home and in doing so bent the metal lift arms which raise the roof and did some damage to the track (I’m pointing to these issues in the pictures). If you’re mechanically inclined you may be able to fix this yourself by fabricating new metal arms and purchasing a track, I am very much not mechanically inclined and fairly accident prone so we’ve decided to sell this. As it currently stands I can not lift the roof since I stripped the teeth of the crank, it would need to be manually lifted and propped up to work on.
I spoke with Bill (owner of Hallmark) and he suggested simply replacing the HECO lift system with a much sturdier Super Manual Crank system, which will cost around $3,800. Once the metal arms are fixed, you basically have a new camper since everything else has been updated with new parts. So you could either fix the HECO lift arms and track or replace it with a new Super Manual crank system.
Dimensions - 6.5” long, bed rail clearance is 22”. Currently sits on my first gen Tundra.
Located in Durango, CO
$12,500
DanoWall
