SOLD
Tim RR
*** Sold ***
International 4x4 Expedition Truck (sleeps 4)
(No Owner Financing)
Contact Information: RedRoverAdventure@gmail.com
Vehicle is located in St. George, Utah
Our family of four (2 adults + 2 teenagers) just completed an amazing 27,000 mile journey through 32 states in this proven expedition/adventure truck (see our adventures on Instagram @RedRoverRightOver). We loved everything about it, but our children want to complete high school in person, so we are selling in order to make that happen.
This is a well cared for vehicle with custom bamboo cabinetry and stainless steel surfaces throughout. No expense was spared on the massive battery bank, solar array and electrical system. Enjoy extended off-grid adventures with ample water capacity, seemingly unlimited electrical power and abundant storage (seriously, there’s a lot of storage).
The rig is based on a commercially available International 7300 SFA 4x4 that keeps up with the other trucks on the highways and holds its own on the backroads. It has been a great truck with parts, tires and service readily available. The vehicle itself is registered/titled as a motorhome and is straight forward to operate. This rig is now available and ready for your next adventure!
Cab and Chassis
  • 2008 International WorkStar 7300 SFA 4x4
    • Factory (OEM) 4 wheel drive system
    • <52,000 Miles and <2,450 Engine Hours! (No PTO installed)
    • 27,000lb GVWR (Class 7) / ≅ 21,600lb Curb Weight (fueled)
    • Truck Dimensions ≅ 30’L x 8’W x 12’3”H (overall height varies with vehicle configuration)
  • Maxxforce DT466 – No Diesel Exhaust Fluid (DEF)
  • 5 speed Allison 2500 Rugged Duty Service Automatic Transmission
  • 2 speed transfer case Hi/Lo/Neutral - Low Range 2:1
  • Leaf Spring Suspension with front TTM Linked Air Ride Suspension Assist System and new shocks
  • Antilock (ABS) Air Brakes with Automatic Slack Adjusters (ASAs)
  • New General Grabber OA WB 425/65r22.5 Tires on aluminum Accuride wheels (Single Rear Wheel Conversion by International)
    • Prior Tires: Michelin XZL WB 445/65r22.5
    • Matching Spare tire included - carried on cab roof with hoist or rear lift system
  • 50 Gallon Main Diesel Tank with additional 20 Gallon Reserves Wavian Cans
  • Air Ride Cab equipped with two fully adjustable, and very comfortable, air ride seats
  • Cruise Control, Idle RPM Control and CAP (Cold Ambient Protection) System
  • Climate (HVAC) Controls - Air Conditioning is cold
  • 5x12V and 4xUSB Power Ports in Cab
  • RAM Mounts in Cab for Communication and Navigation - two X Grip Universal Holders included
  • Flexible step-through from cab to living habitat (lockable)
  • 4 Exterior Cameras with large multifunctional monitor in dash
  • 5 adjustable cup holders
  • 360deg exterior lighting with wireless bluetooth controls
  • Rear Mounted Ramsey 9,000lb Winch with 20,000lb Synthetic Rope & Snatch Block
  • Rear motorcycle/bicycle lift with qnty 5 standard 2” receivers for mounting factory available accessories - 400lb max payload (previously carried four heavy radmini step-thru ebikes and a hitch tray)
Living Unit – Technical
  • R-17 full four season construction - Fiberglass Body Exterior Dimensions 19’Lx8’Wx7’8”H
  • Total Composites German Engineered fiberglass composite foam sandwich panel & extrusion - thermal bridge free construction
  • Rail-on-Rail articulating torsion-free subframe
  • Interior Height: Min Standing 6’4” / Max Standing 7’0”
  • EuroVision awning dual pane acrylic windows with integral black out shades & bug screens (3 Large / 3 Small)
  • LED Lighting throughout - Two zone main lighting (dimming) and multiple white/red marine point of use lights
  • 12VDC, USB and 120VAC receptacles available throughout habitat living areas
  • Dual Band 700MHz 4G LTE Cellular Data Booster - Cab Top Mounted Omni Directional Antenna
  • DC digital switch panel for pumps and lighting with wireless bluetooth controls
  • Frost Free 105 Gallons Fresh Water (3x35gallon electronically selectable tanks)
  • SeeLevel II tank monitoring system - interior and exterior displays
  • 3 Stage Fresh tank prefilter system - Sediment, Carbon and UV
  • 3 Stage Drinking water filter train - Sediment, Carbon and Carbon Block
  • Point Source Electric Hot Water System
  • Frost Free 25 Gallon Gray Water Tank
  • Exterior fresh water wash down connection
  • 4x 300Ah (1200Ah!) 12V Lithium Batteries each equipped with independent BMS and wireless monitoring systems
  • 6x 330w Panasonic solar PV panels (1,980 watts total wired in parallel)
  • Alternator Interconnect System
  • 2x Magnum Dimensions Solar PT-100s MPPT Charge Controllers
  • 1x Magnum Dimensions MSH3012 Pure Sine 3000W Hybrid Inverter - 120VAC
  • 1x Magnum Energy Advanced Remote Control (ARC)
  • Marine Grade Electrical Components (BlueSeas Distribution Panel, Battery Isolation, Breakers, Bus Bars, Fuses, etc.)
  • 9,000btu mini split heat pump – Air Conditioning and Heat
  • Diesel Cabin Air Heater
  • Exterior 15A 120VAC outlet
Living Unit – Convenience
  • Kitchen equipped with Large 30” Convection Microwave Oven, exterior ventilation and Induction Cooktop
  • 2x Energy Efficient 78L ARB Compressor Refrigerator/Freezer with remote monitoring
  • Stainless Countertop, Deep Integrated Kitchen Sink with Fresh and Filtered Drinking Water Tap
  • Compartment prewired and plumbed for Washer/Dryer combo! (Washer/Dryer not included)
  • Ample storage throughout – underbody, garage, cab roof and living area interior
  • 6 person dinette – electrically converts to 2 person queen bed with reading light
  • 2 twin beds (30x78), bunked, each with privacy curtains, reading lights and windows
  • Separate ventilated shower cell with inner retractable door and European style mixing valve for optimum temp & pressure control
  • Private bathroom with mirror, GFCI 120VAC, filtered water bamboo sink, Natures Head Composting Toilet and power ventilation
  • 2 non-DOT belted adjustable swivel recliner seats with convenience lighting
  • Sliding Bamboo privacy door between the two sleeping compartments
  • Illuminated garage area fitted with L-Track for secure stowage. Straps included.
Extras
  • Tire Changing Equipment (12 Ton Jack, Lug Nut Torque Multiplier Set, 2x 30” Tire Irons, Bead Lube, etc)
  • Air Hose and Chuck for the 13.2 CFM Onboard Air Compressor
  • Grease Gun + Quick Lock Coupler
  • 42,500lb Snatch Strap and Shackles (4inx30ft)
  • 30,000lb Winch Strap / Tree Saver (8ft)
  • 4x Waffle Board Style Recovery Ladders
  • 12ft Pole Saw / Tree Trimmer
  • Fire Extinguishers (Cab and Living Unit)
  • Smoke Detectors (Living Unit and Garage)
  • CO Detector (Living Unit)
  • Water Detectors
  • New Entry Door Magnetic Bug Screen
  • Manuals
Known Issues
  • Small exterior fiberglass repairs and normal use scrapes and scuffs
  • One underbody storage box used for storing leveling blocks and wood is damaged but functional
  • Outside temperature indication can be affected by direct sun
  • Insignificant/Non-Visible water damage to top of one freezer slide outs (forgot to reinstall freezer drain plug)
  • Some drawer and cabinet latches are tight
  • Small section of fabric wear on driver side air ride seat
RAM5500 CAMPERTHING
OG Portal Member #183
I love this rig and i have followed you and your adventures on IG for awhile! Sad to see it go!
Question. Who did the build out of the interior?? Its beautifully done and very functional!
GLWS
shortbus4x4
I think that truck was in the International dealer I work at a few months ago for some maintenance. Pictures don't do it justice, way better seeing it in person.
billiebob
No idea on price/value, but this is one of the best oversize,overland rigs ever. Well done, best of luck selling it.
International and the DT466 are a standard with 40 years of history.
Jonnyo
did you build some kind of crash cage for the passenger? any more details on this? i love everything about this rig!!!!
Tim RR
I wouldn’t call it a roll cage as it would not meet that standard (Eng/Fab) nor do I believe it would completely hold up on its own to a violent 13ton rollover. However, I do believe it offers protection, particularly from imploding walls and furniture. It is far better than nothing.
I decided to build it after watching RV crash test compilations ? on YouTube. If you have never watched these it is amazing how quickly everything collapses/disintegrates into the passengers who appear to only be belted to small metal frames or just the wood benches/chairs they are riding on. Typical production RVs with typical shoddy materials and construction....
As a bonus our kids found the cage was useful for organization and storage.
Tim RR
Prefer to avoid laundromats? This truck is plumbed, wired and ready for a washing machine/Dryer!
Compartment prewired and plumbed for Washer/Dryer combo! (Washer/Dryer not included but readily available)
We removed the washer/dryer combo when we went full time, but there was nothing wrong with it. We simply preferred to do laundry in multiple machines (all at once) at the laundromat every couple of weeks. It all comes down to personal preference, but the works been done and it’s simple to install.
