Mounting E-Track to an Econoline E-350 van for Bed Platform?
Hello,
I have a 2011 Ford E350 Quigley 4x4 cargo Van. The rear is all bare metal at this point. I would like to put some E-tracks on the walls to be able to install (and remove) but I am concerned about the strength of the sheetmetal reinforcements on the interior walls. This is a work van, so I need the rear cargo space open most of the time, but want to put a stable bed platform in for camping occasionally.
Has anyone done this (I'm sure)? Should I panel it with plywood and go into the plywood, or use some thicker sheetmetal to spread the load over a greater area?
Thanks for all input.
jungblud
The old school E350 has solid sheet metal in the back so it can definitely stand up to some weight. The key is how it is done of course.
I think one key is to use proper fastening using some sort of expanding insert; and having enough fastening points along the length of the attached rail. I have a nutsert kit and plan to do this over the next few weeks once I finish my floor.
A question for you is what sort of rail are you attaching? The reason is if you use some sort of square rail, the rotational force depending on the hardware attached might not be adequate to avoid some twist.
I'm going with a single 8020 extrusion on each side but in a rectangular shape to maximize surface area that is bracing the wall and supporting the bed. The other option I'm looking into is the approach taken on this video:
Transit Conversion - DIY 3 Panel Aluminum Bed
Here a large plate of aluminum was bent in a brake and a custom channel with HDPE was used as a connection from the bed frame to the bent piece. Very clever but requires some custom work which you may not have access to achieve.
What I was planning on using was E-track, because it has so many options, and I already have some from the last van I had.
I was thinking on using 2x4s across the span of the van, and then a couple pieces of plywood on top of them to make the platform. When I'm not using it as a bed, the e-track can be used for light duty additional tie downs for stuff in the back (I haul lots of cars and parts).
Roaddude
Long time off-grid vanlife adventurist
I've used my long wheelbase GMC van for hauling cargo and for adventuring.
I have e-track in the floor, and would not hesitate to screw lengths into the wall bracing, though suggest Riv-nuts or through bolting where you can, to reduce/eliminate vibration loosening self-tapping screws.
If you're putting ply on the walls anyways, it depends on how thick as to whether you'd screw e-track to it, or go through it into the wall braces.
As mentioned above, several attachment points along the length is advised. If attaching on top of plywood, I'd have those points at the vertical braces go into metal with Riv-nuts, and the rest into the ply.
Another option is to build side cupboards like above at the height you want your bed platform to be. I have two simple folding bed platforms, each as wide as a sleeping bag, with 3" upholstered cushions. I usually just carry one, though bring the 2nd if someone else is coming along. Each bed platform can go along either side lengthwise, or across the width anywhere along the lengths of the side cupboards, supported in the middle by a crate the same height as the side cupboards or by two crates if setup along one of the sides.
Across the width like this:
My side cupboards hold a ton of gear, straps for the e-track, and tools, etc. They are flared out to the rear to full width of the doors and narrow slightly to 52" wide between wheel wells and beyond. That way I can funnel a pallet or sheet goods or whatever into the cargo area without banging up the ends of the side cupboards.
A lot of vanners want their bed platforms larger and going across the whole width more permanently and often a bit higher to provide a 'garage' of sorts underneath accessible from the rear doors.
I opted not to do that because I like keeping my bike in there, I like the more walk-through aspect possible in a van, and like that I can fold up the bed board and stow it and the cushions just the other side of that half-bulkhead, even when on the road. With this arrangement, it's a quick and easy switch from adventure van to empty for work or helping someone move, etc, and still retain considerable storage space in the side cupboards. They have simple lids with finger holes. Worked finest kind for years.
If using track on the walls to support a bed platform or to secure other gear, there is also airline L track that is favored by some. If you already have e-track, you're all set.
Direwolf
895 8556y 6.96t 6. 5g4 75b 4 s. 5366 [565 5rt 5 86g 6 0. 53dy 7 85y.3 5 76 573 759 7, 4u
.677. 5 5 7b
5g ^6. 58545r 65 85 5 754gDz
6 610-10-4743 I
5
79s 5.9z5z953 7. 5.985 7 85y695 495g6 9 59f 686468 5g.986 7 . 5
Sent from my SM-G960U using Tapatalk
Thought I would give a little update. Since my last van had e-track just screwed into the interior reinforcement metal, thought I would try that here. The E-track offers a fair amount of stiffness, and most of the loading will be vertical (I'm not really using it to tie down cargo, etc) so I think I'm OK using self-tapping screws.
Used some 2x4s across and cut some pieces of plywood to fit. Now, I need to get a roll of foam for a bedding mattress.
BobPeanut
I just got a Chevy Express and have been looking into E/L track. Your approach sounds like what I am going for! It’s important for me to have a modular and removable setup, which seems less common (or maybe just less posted). Your van looks great, too. Do you have a build thread?
Schoess
First of all, I would like to say that I absolutely love your simple, modular and effective approach on your express van build here. As you mentioned in the last sentence of this post, I would like to mount E Track to my walls to use as the supports for the bed. I plan to use mine as a moto van with the ability to take bikes out and prioritize living space. I am trying to wrap my head around the best way to mount the E track. Ideally it would be 14ish inches off the van floor and perpendicular to the floor at 90 degrees. It needs to be able to tie down 2 bikes and also hold a full size bed with 2 people on it. Any ideas?
Ozarker
Use Riv nuts, my E250 had e-track with that system, attached to the ribs.
It was even to the rear/side door latches inside.
E track has several types of hangers, one type has an L with 2 steel rods pointing out to the interior, these are designed to hold electrical cords or hoses wound up or it could hold a bicycle. 4 or 6 of them could support a bed.
Problem is, where do you carry the bed when not in use? Pulleys can put it on the ceiling and lower it for use.
What's much easier is to use 2 single or one double folding camp cot, the van won't rock as much using cots!
Schoess
Yeah I am well aware of riv nuts, and I do plan to use them. The main issue is that the ribs of the van are not perpendicular to the floor so I need to make some type of angled spacer to bring the E-Track out to 90 degrees.
Also as far as the bed setup, I have a plan in mind using the 2x4 hangars that mount in E-Track. I will utilize the inexpensive, lightweight and comfortable Ikea slatted bed design shown here. Bed Design
I will custom make the frame to accommodate them and it will be movable throughout the van on any of the E-Track mounts. All of this relies on the fact that I will have securely mounted E-Track that is square to the floor
