Rockpals Refridgerator
bluejeep
just a guy
I've used mine several times (short periods of use) and other than not behaving well when set to Fahrenheit it has been flawless. Cools rapidly on high then goes into ECO mode
bguerrero
When I run it on 12v car battery I will Get a F1 code when voltage drops below 11.8 v. Not good if you have meat in the refrig.
86scotty
Cynic
You need more power. You shouldn't be letting any battery drop below 11.8. Basically every newer DC fridge available has low voltage cutout like this, you won't get around the problem except by improving your power reserves (battery).
