Sold 1994 Mercedes Benz SK1824 4x4 truck. 79,000.00 OBO
rlava
FOR SALE: 1994 Mercedes SK1824 4x4 camper Truck.
MILEAGE: 143000 miles
PRICE: $79,000.00 USD
MB 1824 4x4 chassis ,
Powered by extremely reliable all mechanical OM 401la 6cyl diesel engine, turbo & intercooler matted to a 6spd manual transmission with overdrive & dual high/low range four-wheel drive, with locking centre & rear differential.
Very capable truck in challenging offroad terrain while comfortably cruise at hwy speeds, 65mph@1900rpm. New clutch(4000miles),
Clean rust free cab, air ride driver seat.
Heavy duty foldup rear bumper to allow better departure clearance in offroad conditions.
Removable bike carrier mountable on front bumper.
Heavy duty tire carrier mounted to chassis.
Michelin XZL 365/85r20 tires(4000miles)
1 set Heavy duty tire chains.
HABITAT:
The existing interior can be completed or can be removed and sold as an empty shell if someone wants a blank canvass to build their own living space.
FRP total composite panel 4 season cold bridge free construction, 16'L×8'Wx7'H exterior dimensions, mounted on a torsion free 3 point subframe to allow chassis to twist on offroad terrains.
All fabricating professionally done by a Mercedes(unimog) trained specialist/mechanic.
Arctic tern entry door.
Arctic tern dual-pane acrylic windows w integrated bug screen & blackout shades.
Arctic tern access hatches to garage area, full 8'width accessible from both sides.
Permanent entry ladder & foldable aluminum stairs.
GALLEY/DINNING:
Wood cabinetry throughout( lots of storage space).
Stainless steel sink
2 burner stove/oven- propane fuel.
Large slide out pantry, cupboard & drawer space.
Dining booth converts to large 2nd sleeping area(46"w × 76"l)
BED AREA:
Double size mattress 54"×72"
Clothes storage compartments.
WASHROOM:
Wet bath, stainless steel sink w pullout faucet for showering.
Natures head compost toilet.
ELECTRICAL:
simple 12v electrical system to power 12v components: LED lights, diesel heater fan, USB ports, fan.
Portable solar panel: 180w with charge controller.
Battery bank: 2x125ah agm batteries(2020)
12v diesel air heater.
WATER SUPPLY:
4X5 Gallon water jugs with quick disconnect fittings for ease of changing.
Hand pump for drinking water in kitchen.
25 gallon grey water holding tank.
Warm natural cork flooring,
Large windows for great cross breezes and ventilation,
Ultra quiet 12v fan keeps air circulating efficiently.
Fully insulated frp panel construction provides excellent insulation in cold winter temps as well as in hot desert climates.
Comes with: 1 set oil, fuel, engine air filter.
Air dryer filter
Valve cover gaskets
90gallon diesel fuel tank.
Tried & tested Mercedes engineered 4x4 chassis makes this a true robust/capable overland truck.
Its a great base to have the finishing technical systems installed to someone's personal needs/requirements: electrical/solar
Plumbing/hot water system
cliffi
Questions:
1. Any fridge / freezer?
2. Size of fuel tanks - range is ?
3. Block heater?
Thanks!
rlava
no fridge at this time, we have an isotherm fridge waiting in bellingham washigton, once border reopens it can be picked up and installed. space for is ready for fridge above pantry, currently has 125L fuel tank, 375kms/range, comes with a 325L(90g) fuel tank to be installed. has plugin block heater.
KSatYVR
Bump because I see it on the way to Whistler, but with border still closed except essential travel it is difficult to sell to US. Hope the border opens soon ??, then I can go to my place in Washington state ?.
Hamstorm
Have any more info on that motor? I've been looking for days and can't find anything useful. Is it rated for 240hp? GVW.. is it really 18 tons? How is the ride and what is the current weight? Any ideas on fuel consumption? It's hard to find technical data for these trucks.
iStan814
