BorealOverland
On my last camping trip i used my DIY kitchen for the first time and it worked great.
But because i had to place it on the tailgate getting to my other gear in the back of the car
was not that easy of course.
expeditionportal.com
So this is what i made:
And this is how i build it:
I decided to build a pull-out platform to make life a bit easier on longer trips..
Because i like to keep the car relative light weight since it's my daily driver i did not want to use
a (heavy) wood base plate in the back of the car to bolt the pull-out platform on.
So after some thinking i decided to use a 2040 aluminum extrusion as a crossmember
(sorry don't know a better word in English for it) and bolt it to the factory tie down nuts behind the back seats.
Because they lay a bit deeper in the floor i had to fabricate two solid spacers.
This chunky block is what i had laying around.. Try and use stuff i already have.
Something like that.. two solid spacers to bolt the crossmember on too.
So with that sorted i now could figure out how to build the pull-out platform and how to bolt it to the crossmember.
Taking a couple 1000 measurements lol.
After al the measuring i had a fairly clear idea how i was going to build the platform and the dimensions
i can use.
To be continued..
"8020" Kitchen Module, first time use..
He guys! Last weekend i finally had the chance to use and test the kitchen module i made some time ago. (Build here: https://expeditionportal.com/forum/threads/diy-kitchen-module-from-aluminum-extrusions-8020.219492/) The kitchen module is basically just a frame out of aluminum extrusion with 2...
i can use.
To be continued..
