(SOLD) RAD Adventure Trailer $20,000 (NEW)
Rad Coast
I’m a custom teardrop trailer builder in southern California and I built a trailer to be a rental but I don’t have time to deal with renting a trailer right now so I’m putting it up for sale. I pretty much went all out on this build geared towards a Toyota tow vehicle keeping it light and wheel matching but maxing it out on options. I built it to be the best!
If you have any questions or want to see other builds or build photos message me @ rad.trailers@gmail
-5x9 1400 lbs dry weight (7 wide 13.5 long and 6.5 overall)
-Fully insulated 1.5 inches R-Tech in the walls roof and hatch 2 inches in floor
-Welded steel frame
-Anodized aluminum skin 0.063 on centre with black anodized 0.040 on sides
-Full aluminum skid plate
-oversized steel rock guarded fenders
-Custom roof rack legs and Rhino vortex cross bars
-All exposed frame is rock guarded
-Max coupler articulating hitch
-Rear 2” receiver
-3 5000 HD tube jacks
-Full Baltic birch construction no softwood 2x2’s
-Timbren 1 tone HD axel less suspension with 4 inch lift (23 inches of clearance)
-Toyota TRD Pro rims (purchased from Toyota) with Toyo open county 265/70 R17
-10 inch electric brakes
-7 blade trailer plug with breakaway switch
-30x36 inch double doors with sliding screened windows (4 inches wider than most trailers Timberleaf, Escapod.. etc.)
-10 speed maxx fan with remote, rain sensor and thermostat
-Stargazer window
-Upgraded interior cabinets with pull out table
-All led lighting with built in dimmers
-Upgraded galley with locking cooler slide with 12 volt power for electric fringe/cooler
-6 inch full size memory foam mattress
-200 watts of solar
-30 amp mppt charge controller with upper galley monitoring system
-Progressive Dynamics charger/converter shore power 30amp service
-100 amp hour lithium battery
-6 USB chargers and 3 12 volt power points
-2 GFI protected outlets
NatersXJ6
What does “upgraded” mean with respect to cabinets and galley? Didn’t you build this custom? What did you “upgrade” from and to?
Rad Coast
They are not the cabinets that come in my base model and actually have a new pull out table I did custom just for this build along with the doors for the cubbies and the drawer under the power centre
Rad Coast
-Welded steel frame
-Rear 2” receiver
-Stargazer window
-200 watts of solar
  • Like
Reactions: plh
