Hi Mileage Tundra? Owner Opinions Wanted
D
Deleted member 9101
Guest
Thanks for the info rruff.
I'm just thinking that a larger sidewall would be better at dissipating heat when towing.
Countless people tow with 20" rims and have zero issues...lol. My dad has been towing with 22" rims and he has not had a single problem with heat.
  • Like
Reactions: WVI
rruff
20" rims are fine for towing; more sidewall is good for offroad. Pretty sure the aluminum rim dissipates better than the rubber tire. If you have high load rating tires, they won't be "challenged" in any case. Less sidewall will probably squirm and sway less as well.
seth.c96
