This is a home built Expedition style camping/adventure trailer. Great for hunting trips, kayak fishing trips, or just a “bug out” trailer. It is built on a 4 foot by 6 foot trailer frame with a 2000lb rated axle and “5 on 4-1/2” bolt pattern hubs (jeep rims will fit). Year long project trailer was completed 11/20/20 and only used 3 nights. Top down and front to back description- Smittybilt Overlander XL roof top tent, includes king sized foam mattress and LED interior lighting with usb charging ports. Tent rack includes 4 multi-directional LED spotlights with individual waterproof power switches. ARB awning 6.2 feet by 8.2 feet with LED light strip. Main-box roof rack with spare tire carrier and full size spare tire. 2 inch removable hitch coupler. Fold away tongue jack. Tongue box- houses electrical supply for trailer and includes- 110v shore power connector, NOCO Genius Mini 4 amp battery charger/maintainer, Ever Start 29DC 100 amp hour deep cycle battery (new 9/20), battery disconnect switch, 6 circuit Blue Sea Systems ST blade ATO/ATC fuse panel, 5 gang FXC aluminum rocker switch panel with backlit switches individually wired and fused, 110v outlet inside box and 110v outlet outside box with weather proof box, 12v accessory panel with voltmeter. Main box- side door access to cooler/fridge slide-out and storage shelf above (interior light w/switch above door). Rear door access to kitchen slide-out and main storage area (interior light w/switch above rear door). Both doors are weather sealed and door latches are keyed alike. 14X6 5-lug on 4.5” Chrome Mod trailer wheels with high pressure bolt-in chrome valve stems (spare on silver painted rim), wheel locks w/key (key in tongue box), Tires- Carlisle Radial Trail ST205/75R14. Ground clearance- axle 12 inches, trailer frame 23 inches. Box exterior skin- 26ga painted metal (charcoal) with painted aluminum trim secured with stainless screws and sealed with butyl tape above and below metal siding. Yes, title in hand. You can see the entire build on youtube. The sale price is the total cost of my build...NOT including my time of course. PM me if you or someone you know is interested.
