Dometic/SMEV 2-burner Propane Stove - Boulder, CO $300 + shipping
Pgopinath
I have for sale an unused (except to turn it on and test) 2-burner Dometic/SMEV 2-burner propane stove with an additional 1lb cylinder adapter. I was going to use it in my Jeep build and then sold the Jeep and got an XPCamper which has its own cooktop.
The stove is in excellent condition and everything functions perfectly. If you are local and are interested you are welcome to come by and test it out with a 1lb cylinder. It is sold out everywhere I looked. I am selling just the stove and the 1lb adapter - no box, documents etc.
It is also posted on local Craigslist because I like the aggravation of dealing with all the scammers and the inane questions on CL.
Specs from online:
High Quality
SMEV is a manufacturer based in Italy, making high quality RV and marine products. All SMEV's products are made of 304-L category stainless steel, a type of steel engineered for heavy industrial applications. To ensure maximum resistance against stains, SMEV also chooses the 18/10 alloy, that is a steel formulation that guarantees 18 parts of chromium and 10 of nickel. The resulting products are strong, durable, light and free of any wrinkled or shaded areas. The integrated lid is made of heat-resistant safety glass.
Ignition and Fuel
The SMEV PI8022 is fueled by LP-Gas, with a piezo ignition. The left burner is 3700 BTU and the right burner is 5900 BTU. SMEV uses JetFlow technology, consuming 33% less gas than competitor models while delivering much higher temperatures. SMEV cooktops require the hookup of low pressure propane before the regulator on the appliance.
Product Information
Overall Dimensions 18 ¾” x 14 ½”
Cut-out Dimensions - 18 ½” x 14 ¼”
Cabinet Depth - 4-1/2”
Burner Grate Dimensions - 7 ¼" & 7”
Power Source - LP Gas (Propane)
Gas Pressure Requirement - 11" W.C.
BTU/hr Rating - 3700 and 5900
Ignition - Piezo
Safety Shut-Off (Thermocouple) - Yes
Burner Style - Sealed
Fastening Method - Hardware
Terms:
1. Payment by PPFF, Venmo, check (will need to clear first)
2. If you are local you are welcome to test it out.
3. It is sold as-is with no warranty expressed or implied.
4. Buyer pays for shipping via your preferred carrier
seth.c96
