1988 Ford E350 Jamboree 4x4 Custom Camper
traverssmith
This Class C Motorhome is a completely unique vehicle. There’s nothing else like this one.
Cab is a 1988 Ford E350 with a 460 EFI V8
3 speed automatic transmission
I am the 3rd owner of this vehicle. It has all of its service records starting in 1991, including the original window sticker from the dealership in Chico, California
Fiberglass body, lived 90% of it's life in San Diego, CA where the conversion took place
Fully self-contained with cold AC
Bath, shower, with new power vent
4 burner stove and oven, original and as clean as new
New vinyl floor
New custom front bucket seats
New upholstered cushions on couch and dinette
New oversized Dometic stainless-steel refrigerator
New interior LED lights installed into the classic interior dome lights
3 beds, over cab, the dinette area, and the couch turns into a bed
New 8”memory foam mattress with new sheets and comforter
Lots of storage
Lots of windows
30 gallon fresh water holding tank
10 gallon propane tank
Large holding tank with 2 new drain hoses
Exterior:
Custom built LED headlights
LED tail lights
54" LED front light bar
Four 2" LED lights around body
All LED running lights
2 high resolution cameras (1 on back, 1 on passenger side) with 7" display screen inside
New custom steel bumper on front with new Warn XZR 12,000 lb winch
New bumper in rear that hides the holding tank drain hose
Custom rear bumper rack and storage box with trailer hitch receptacle. Wires are run to it for a trailer connection but it doesn't have an outlet installed. The rack was custom built to carry the weight of a motorcycle
8 new Cooper Discovery off road tires
Locking front hubs for 4-wheel drive. Has 2 High, 4 Low, and 4 High
New dual spare tires on roof with new vinyl wheel covers
New exhaust system
New catalytic converter
New radiator and cooling system service
Transmission service including drain and fill, and new pan gasket
After market Billet oil dip stick
2 large gas tanks
Cab and motorhome wrapped in 3M Realtree Xtra Snow camo (I believe this 3M product has a lifetime warranty)
New custom awning
New dual steel retractable steps at camper door
New Bully steps at drivers and passenger doors
Onan Emerald 1 generator with 37 hours
Engine, transmission and transfer case are a year newer than the coach
Runs great
I had a local shop do a complete vehicle inspection last fall, including breaks, suspension, oil change, etc... Then I put it in indoor storage for the winter. While it was in storage I did the annual inspection and sealing of the roof and all windows, and I installed new roof vent caps.
The camper just came out of storage a few days ago.
Odometer says 71K but it was not connected when I bought it, and still isn't now.
I have never used the water pump, hot water heater, shower, or sinks for running water, so I can't speak to their functionality. I have used the grey and black water holding tanks and they work and have no leaks. The plumbing from the kitchen sink to the holding tank is also in good working order.
I have played with the generator a little just to check it out. It requires a little finesse to get going and runs great.
Plug in power works and will run the AC which cranks!
There are some places where the wall paper is a little wrinkled or has a pealing edge. I sealed all of the exterior window frames. There are some places where the rubber window gaskets could be replaced. There are a few signs of normal usage wear and tear, in general it's in amazing condition. I've done extensive painting and sealing on the exterior. On the interior I've gone through every nook and cranny with a flashlight and shop vac and it’s as buffed out as when it rolled off the factory floor.
Extremely comfortable to live in while working remotely, use as a guest house on your property, live in it for the summer, camp and go anywhere.
I'm happy to answer any additional questions. It’s currently located in Wilson, WY. I’d love for this to go to a good home.
$49,000 obo
crostopher
