SOLD 2 Renogy Solar Charge Controllers
Fritzoc
From Amazon:
PLEASE NOTE- one is the newer version that is Bluetooth compatible and LI compatible. The other is the older model.
Compatible with 12V and 24V system; Deep cycle Sealed, Gel, Flooded and Lithium battery option ready.
The Adventurer is a negative ground controller. This ensure compatibility with any negative ground system, which is the standard and most conventional way of grounding. Any negative connection on the solar module, battery and load can be safely earth grounded as required.
Smart 4 Stage PWM charging (Bulk, Boost, Float and Equalization) and temperature compensation increases battery life and improves system performance. Intelligent protection against: reverse polarity, overcharging, short-circuit and reverse current.
Backlit LCD screen for displaying operating information and error codes. 5V 2. 4A USB port on the front display can be used to charge mobile phones, tablets, speakers, etc. RS232 port allows communication with BT-1 Bluetooth module and usage of Renogy BT smartphone app.
Designed to cleanly flush mount on walls, providing a sleek, integrated look. An included Surface Mount Attachment allows for versatility in mounting.
emohn
Hi Fritzoc,
I’m here in Louisville and interested in picking up the charger+Bluetooth model - potentially the other as a spare (or for another project) as well. Let me know if you’re around this week and able to meet up to sell.
Thanks,
-Erik M
Fritzoc
Hi Fritzoc,
Thanks,
-Erik M
Eric-
DM sent
Fritzoc
Hi Fritzoc,
Thanks,
-Erik M
Eric- Verifying that I sent you a direct message. Did you receive?
dhuss
