SOLD - 2015 Kimberley Kamper - Bend OR - PRICE REDUCED $35,000
joemama
SOLD - 2015 Kimberley Kamper Limited Edition - Located in Bend, OR - Asking $35,000
Ordered direct from the Kimberley factory in Ballina, NSW Australia and optioned to our specifications, this 2015 Limited Edition Kamper has been nothing short of an amazingly comfortable, capable, and reliable trailer. The attention to detail and level of quality in these units is unparalleled. This trailer has been able to go anywhere our 100 Series Land Cruiser could take it, without hesitation.
Unfortunately for us, the time has come for us to change things up with our camping vehicle(s). With young kids now grown up, the Kimberley doesn’t get the use it deserves. As you will see from the photos and description, this turnkey setup is ready for the next round of adventures. I have listed the standard features of the 2015 Limited Edition, as well as the upgrades we added from the factory, along with the extras we have added back here in the USA.
In 2015 Kimberley offered four Kamper base models to configure from, they were the: Classic, Limited Edition, Special Edition, Platinum Edition. We found the Limited Edition to have the best all-around starting point for us to configure from.
Worth noting, I am an aircraft mechanic by trade, with nearly 30-years experience. To a fault, I am detailed oriented and extremely meticulous about taking care of and maintaining my equipment/gear. I believe in being open and honest, as I would hope others would do for me. This is a serious investment and I am an open book to how this trailer has been used, maintained and looked after.
I have an extensive description and spec sheet attached as a PDF. I ran in to character limitations on the posting, so elected to attach it in the PDF format to get the full description posted. Please feel free to inquire with any questions.
General Condition:
As good as new condition. That may sound boastful, but you will see for yourself in the photos and description.
The Kamper has been garaged when not in use since arriving on US soil.
The Kimberley decals were removed to keep any paint wear/tear equal, although I haven’t seen any paint fade or signs of deterioration.
Paint protection tape added in any high wear areas.
Kamper was opened up, washed inside/out (canvas, painted surfaces, drawers, Delta boxes, etc) and fully dried after each trip. There is no mold or dry rot issues anywhere on the Kamper.
issues:
2.5’’ x 3.5’’ hole in the “Rhino” (bed liner coating) on the left propane tank stone shield. Both propane tank stone shields have served their purpose in deflecting gravel. At some point, they could be re-coated.
Specs:
Dimensions: 195’’ long x 71’’ wide x 63’’ tall.
Weight:
Tongue: 330 lbs
Tare: 2,125 lbs
2015 Limited Edition Standard Features
  • Laser cut, interlocked, hot dipped galvanized chassis.
  • Independent trailing A arm suspension.
  • Air bag suspension.
  • Mono tube Fox Shock absorbers tuned for air suspension.
  • Treg off-road hitch coupling.
  • Rhino coated stone shielding.
  • Silver high quality gloss paint.
  • Semi-Pneumatic jockey wheel.
  • 1500 liter Delta Box front storage.
  • Fridge Slide with locking roller bearing slides.
  • 120 liter (31.75 US Gallon) rear water tank with quantity monitoring system.
  • Cold water filter.
  • Webasto diesel hot water heater system.
  • Advanced tent body.
  • All weather window.
  • Tent ventilation kit.
  • Integrated Ensuite with walls.
  • Batwing kitchen awning.
  • Kwik Awning 2.0m x 6.7m (6.5’ x 22’) with LED lighting.
  • Stainless steel slide-out kitchen.
  • Integrated stainless steel table for slide-out kitchen.
  • Delta box fridge ventilation fan kit.
  • Uni Cooker slide with split sliding pantry with Wok Burner and BBQ.
  • Vertical pantry.
  • Concealed safe under bed.
  • Swing-away knuckle mount set.
  • integrated pole storage box.
  • Battery bank voltage meter.
  • Anderson plug cable (to tow vehicle connection).
  • 25 watt solar panel on front Delta box.
  • Dual LED reading stalk lights.
  • 2x 30 LED lights over cooker in Delta box.
  • 30 LED light on kitchen slide near sink.
  • 30 LED light on dining bench.
  • 30 LED light in front Delta box.
  • 30 LED light in left Delta box.
  • 30 LED light in under bed storage slide.
  • 96 LED light inside tent.
2015 Limited Edition Upgrade List
  • Tropical roof ($610.00)
  • Kwik Awning complete canvas wall kit ($1932.00).
  • Extra Kwik Awning 2.0m x 6.7m (6.5’ x 22’) with LED lighting ($544.00).
  • Rear bedroom extended ($835.00).
  • Rear bedroom compact ($714.00).
  • Anderson solar input on left Delta box ($100.00).
  • One Touch parking brake system ($1932.00).
  • Under bed stainless steel storage drawer ($723.00).
  • Water tank outlet tap ($70.00).
  • Drawbar extension ($355.00).
  • 40A Battery charger ($100.00).
  • Dual layer foam mattress ($170.00).
  • Boat Loader ($1228.00).
  • Under bed membrane heater ($317.00).
  • Rack sack storage bag ($275.00).
  • Diesel space heater 1.2kw ($587.00).
  • 5 Stud Toyota compatible hubs ($234.00).
  • Fox Shocks ($850.00).
  • Propane bottle hose, regulator and quick disconnect x2 ($155.00).
Additional items included
  • 16’’ Toyota Land Cruiser Alloy wheels, x3 to include matching spare.
  • BFG KO2 A/T 285/75R16 with 13/32’s tread remaining (new tread depth is 14/32’s) x3 to include matching spare.
  • 20lb Propane tanks x2.
  • Spydertrax wheel spacers.
  • ARB CKMA12 air compressor.
  • Firestone dual air pressure gauge and switch panel.
  • 100W solar panel.
  • Aluminum solar panel brakets.
  • Aluminum bench with integrated mount on boat loader.
  • Interstate batteries x6, 35AH - 210AH total (7-months old).
  • Custom made boat loader mount system for receiver hitch compatible bike rack and rain gutter style compatible tower mounts.
  • Yakima rain gutter tower mounts and load bars.
  • Aluminum wind screens for wok burner and BBQ.
  • Campfire in a Can propane portable campfire.
  • RotoPax 2gal diesel can with Deluxe RotoPax mount.
  • Croc Bin trash bag holder.
  • Loads of stakes, guy ropes, water tank fill spout, and other misc items.
  • USB charging hub.
  • Blue Ridge Overland velcro storage pouches (12’’x6’’x2’’)
  • New sand bags for use as deadman.
  • Screw in sand stakes/pegs.
  • Misc spare John Guest metric water system fittings.
  • Misc spare awning pole fittings/parts.
  • Spare air bag.
  • Spare set of brake pads.
  • Spare jockey wheels parts.
  • Trailer cover.
  • 2015 Kimberley Kamper Description and Spec Sheet .pdf
boonedog
Beautiful kamper, still trying to convince my wife this is the route to take. It’s hard to convince her the value and build quality of these.... I’ll be in touch if I can sway her in this direction.
joemama
A couple more photos of the Kamper......
erg
Nice KK. I have a 2005 and it is rock solid. I like the yakima bar add. I may have to copy that. The only issue I have is that I do not use it enough. Nice to see another oregonian with a KK!
joemama
Being able to add the crossbars makes a huge difference in the use of the boat loader, thats for sure. If you need any photos or info, feel free to reach out.
joemama
Please have a look at the first post for a full description, some photos and links to more photos and videos. Feel free to reach out if you have any further questions or need more info. Cheers, Brandon
joemama
Wow, that's something you don't see everyday on US soil. Nice looking kamper. Any photos of the inside?
Jfreeman1103
How long does set-up take? Just getting the tent opened and set. We had a unit that had such heavy canvas tent and cover that it took 30 minutes from the point we got it level to having the tent opened and ready.
joemama
Since the awning and back room(s) are removable, I'll throw out a couple scenarios. Also keep in mind the leveling is completed with use of the airbags and onboard ARB Air compressor, so leveling takes maybe a minute or two to dial it in. Time estimates below are with one person. Two people is less than half the time, due to time savings of not having to walk from one side to the other.
1. Main tent body only: 4-5 minutes.
2. Main tent and awning: under 10 minutes.
3. Main tent body, awning and small rear bedroom: 13 minutes.
4. Main tent body, awning and small rear bedroom: 17 minutes.
Please let me know if I can be of further assistance.
Cheers, Brandon
Ninelitetrip
Very informative write up. Worth a nod from the Admin and a highlight in the classified section. GLWTS.
Boeing or Airbus? :)
