Restored Warn winch- Before and After
VinceAtReal4x4's
Winch repair and 4x4 rescue specialist
I do winch repairs and restorations. I thought I'd share a project I did for a guy who was interested in a period-accurate, as well as, fully functional winch for their 1980's 4x4.
This is a fairly hard to find 100% USA made Warn MX8000 from 1988 (later known as the M8000 or now, M8). It came to me in absolute disrepair with no moving parts. It got a full tear-down, new motor, some expensive synthetic aircraft grease, sandblasting, stainless hardware (where appropriate) aprx. 90ft of USA made Dyneema Spydura rope and the old solenoids were replaced with a modern contactor unit, yet I used an original control box to keep the look. It got a new remote as well. I also had custom tie-rods made (the rods that hold each side together) as these are one of the few parts no longer available for the MX series.
You can see it buried deep inside this old pick-up bumper, which was rusting away in a junk yard. It looks like gold to me, but maybe that's just me! :D
85_Ranger4x4
The M8000 (so was the M6000) was in the accessory catalog for my '85, I have been on the fence about fixing up a old one or just getting a new one.
Neat to see one brought back!
I rebuilt an old M8000 I bought for $100. It required a few parts (new solenoids, new motor, new cable, new wiring pig tail to the controller) but was a relatively easy project with tech support available from WARN Industries and parts available from their dealers.
VinceAtReal4x4's
Thanks for the comments.
Yes Warn supports the older winches, for the most part. I routinely order parts for winches made in the 80's/90's and parts for the 8274's from the 70's-2000's which are all available. The stickers are no longer made for most older series but the newer ones will fit, they just dont look as good.
I've done lots of custom 4x4 related installs in the past and used to import and set up Pinzgauers, Unimogs, older Gwagens, etc. and I kinda dealt with winches often, including my own, and realized there was a need for service outside of the factory approved shops (I've re-repaired stuff they repaired before.)
I do more than your standard service much of the time. There's lots of tricks, special lubes, hardware, wiring upgrades and other things that I've figured out over time that set me apart from your average quick-fix shop. I also have real USA made Dyneema rope that I install with a variety of hardware... all just depends on what someone wants and the budget. Some winches leave me maybe a little better than they were from the factory. ?
Below are two that I finished over the last week. What they looked like when I got them, and the after pics! The MX8000 was from 1987 and fully converted to 24v for fitting to a Pinzgauer.
The 8274 was from 1978 and is going onto a 1980 Toyota PU. It has a new sealed contactor upgrade, 130ft of 3/8 Dyneema, and a new heavy duty motor, with twice the hp of the original motor! (It's wrapped up for transport in the pic.)
craig333
I've had no luck with Warn tech support. Other businesses but not warn. I repaired my warn m6000 and I was surprised by just how dry and rusty it was inside. Cleaned it up, greased it (no special lube, uh oh) and it works great again.
Warn Industries
Supporting Vendor
You can always reach out via PM here as a first step. We're happy to help.
Andy
shays4me
Willing Wanderer
I've always ran the Warn USA made lines on my Jeeps. My first Warn winch was a Bellview model 5687 that I got with my used. I had to replace some bushings to get it going but it was a great winch! Then I bought an m6000 and traded it to a coworker for an old 8274. That winch needed work but everything was available and now it's on the CJ7 along with a bunch of other Warn parts. I've had two of the m8000 winches on my JK's. I think for the price, weight, production history, parts availability and US made you can't go wrong for the occasional use. As for steady use you can't beat an 8274. It's absolutely the best winch out there! Lovin the pics of the restoration.
Speedphreak
Nice job! It's great to repair/restore "vintage" equipment and use it as intended.
I'm a big fan of the 8274. Not only does Warn still make them, but aftermarket support of them is phenomenal.
Plus, I just love the way they look!
ericvs
This is way cool. Do you have any pictures during the process? or a youtube channel to see the restoration process?
nice work! what a cool piece of kit!
Nonimouse
Cynical old bastard
Really nice restoration.
Just a point, Dyneema is a Danish product, made in Denmark by https://dynamica-ropes.com/. They invented it. The origional US 'plasma' rope was made by Puget Sound Rope, from Dyneema strands.
There are very few 'Western' synthetic rope makers and they all use Dyneema strand. Lots of copies from elsewhere, but nothing is as strong or Duarble as Dyneema strand based ropes.
Personally I use SK75
oskarf150
