WTB: SoCal Teardrop
gwalther
In search of a SoCal teardrop 459 Krawler or 510 XS. Preferably an older AT overland version. Not particular on options
mvbeggs
I still have my 2013 AT Teardrop. (cabin by SoCal, chassis and suspension by Adventure Trailers.) We haven't used it since we upgraded to the Black Series HQ-19.
Overland AT Teardrop specs:
Overland Teardrop with Trailing Arm Air Suspension V.4 with air springs and adjustable shocks
Electric Braked Axle Upgrade with 10"' drums
12 Volt & LED lighting package for Overland Teardrop
Roof Mounted 14x14 Fan-Tastic Vent with 3 speed motor
DVD Player. Flip down unit mounted in pass through between galley & sleeping area
Noco Marine Charge
RV-20 controller, 15ft extension cord, weatherpac kit, RV plug male and female
Aluminum storage compartment below mattress
SCT Teardrop roof rack , measurements 48" long x 39" wide x 6" tall.
Hanibal awning with side walls
Propex HS2000 heater
Custom 25 gallon water tank with interior baffle
Overland teardrop kitchen includes full slide out kitchen
Multi Axis Coupler, 6000 lb, Class III
Extended frame to hold a custom storage box on front
Custom front storage box 17 1/2"w x 26" h x 54"L. Mounted w 4" clearance between box and cabin.
2- 200 amp hr AGM batteries with custom battery box
2 x 10lb propane tank brackets
2 x Exterior mounted Pelican cases for additional storage. Mounted on both sides, behind the doors, resting on the fenders.
Might be willing to part with mine for the right $'s.
Private message me if you are interested. Located in the Kansas City area.
gwalther
Noco Marine Charge
PM sent
Cmonsta
What did it go for? I’m lookibg
Not exactly the make/model you’re looking for but I have a similar trailer for sale:
It’s in like new condition and I’m the original owner
frq flyr
I am getting ready to sell a 2016 so cal teardrop, 510xs, fantastic condition, roof basket, awning, solar, propane, cooktop, etc.
located in s ca, Orange County
ping me if interested
update: sold in Aug. 2021
joe
wakepilot
Hi, Are you still looking? I have a 2016 459 Krawler for sale. Just bought a Winnebago Revel so probably wont be using the the Krawler much any more. Its fully loaded!
Options/Features
  • Roof Rack/Basket
  • Roof top Cargo Carrier
  • 50 Qt. ARB Refrigerator, with SCT Fridge Slide
  • 30 Gallon Water Tank with Electric Pump - Sagiv Valve
  • Air Conditioner/Heater with remote control
  • Expanded Metal Cage with Locking Lid
  • Front Storage Box
  • Raptor Liner around Trailer
  • Cabin IPad entertainment swivel mount
  • Cabin Cargo net for pillows and blankets
  • Two 5 gallon wheel mounted gas cans
  • 2000 watt inverter Gen mounted on LOW PRO antitheft Lockdown
  • Scipio Awning with Scipio Annex Package
  • Water Heater / Side Mounted in Lockable Aluminum Box
  • Two RotopaX- with mounts
  • Roof basket shovel and axe mounts
  • Side mounted propane with Tubular LP Tank Cage
  • Panel mount digital volt meter; bright, easy to read red display. Monitors DC voltage from 5 to 25 VDC.
  • Cabin - 110v Outlet with Galley Access
  • Cafe Curtain Rods
  • Additional 12V Outlet located inside the cabin in radio panel. Trailer comes standard with two 12V outlets inside.
  • 12v Outlet / Outside
  • 2 Group 31 AGM Battery with SCT Aluminum Strap Mount
  • 1500 Watt Inverter
  • LED Ground Lights
  • USB Port in cabin (for charging only)
  • LED Porch Lights
  • Premium LED Interior Lights
  • 14" x 14" Fan-Tastic / Vent Fan
  • Off Road - Tube Style Fenders
  • Rear Bump Rails
  • Max Coupler #100-5
  • Road- 2'' Rear Receiver
  • Off Road - Rear Stabilizer Jack
  • Front Jack Wheel- Pneumatic
  • Auxiliary Side Receivers - 2 Additional - 1 1/4''
  • Road - Double Sealed Doors
  • 33’ Cooper Pro-Comp Xtreme MT tires
  • Electric Brakes
