2021 Fuso FG 4x4 Overlander... "West Elk Wilderness Edition"
resolutefool
Hi Joe
The rig is in Gunnison, it has 23310 miles on it, and it is a diesel. It is going to be between 11500 lbs and 12500 loaded. There are several options for AC both roof mounted and external mount. I will get more accurate costs dependent on the unit. Cheers Allan
So about 8,000 lbs. on the rear axle? Are the Toyos rated for that? I can only find the 17" in load range D, ~3,500 lbs. ea.
FXH
Hello,
I left you a couple messages on your website. Please give me a call when you have a chance. Thanks
Hi Yanik
Photos of the cab
For financing this was on a recent thread:
We have used RV Lending Group in the past for two vehicles, and the person that recently bought our Sprinter used them as well. Cant say enough good things about them...courteous, quick and will answer any questions you have. Contact is Kevin Marsh, kevin@rvlendinggroup.com, 866 788 7331, www.rvlendinggroup.com.
Cheers
Allan
chris_the_wrench
Fixer & Builder of Things
Cool rig! How does the passthrough seal work? When you rotate/lift the cab for service work, what's involved to 'disconnect' it?
The rubber boot is attached to the cab and on the other end it has a flange that fits into the cabin and is held in place with 4 screws. When you go to lift the cab you need to loosen the 4 screws and ease out the flange as you lift the cab. Reverse to reattach.
Yanbanjin
Been looking at a Pickup (3500-4500) based set up so I can tow my boat, but this looks like an amazing set up and well done. I'm not so familiar with the Fuso Diesel can this rig tow a boat or Trailer (4-6K)? What is the total weight capacity for the rig? Thanks in advance.
seth.c96
