How remote traveling are you planning?
Not to be a Debbie downer but…How good are you at repairing your vehicles in general?
Do you currently diagnose and repair your own vehicles?
When you are in the middle of nowhere with your Frankenstein MB and you have severe driveline vibration and after replacing the ujoints, had wheels balanced you finally realized it’s a bearing in the transfer case, you find a shop that’s willing to take on the job, you drop the transfer, can’t read numbers on grenaded race, contact MB Germany for a new bearing….do you know the serial number of the truck you got the transfer case out of? MB will have a good chuckle at your expense asking for 4x4 parts on a 2wd chassis. Contrary to popular belief not all parts guys are bending over backwards to help you with your problem.
By miracle you get part, get it all together, travel 500kms, problem reoccurs.. what is your solution? What is not installed correctly? Will the shop you had the work done at fly to where you are to fix the issue they created, assuming they admit responsibility..
Hindsight..How do those 1017 4x4 import costs look now?
What is an original 4x4 worth vrs Frankenstein…
