Dometic cfx3 not holding temp
Gregbarnard
Hello
Seems like a common issue but my dometic cfx3 95 works perfect connected to shore power but intermittently loses temp in fridge and freezer when plugged into 12vdc power . I've tried using different plugs around the van with same results . Any ideas ? Thanks
Greg
67cj5
Man On a Mission
Hello
Greg
Yeah thats a pain, try pulling the cover off where the compressor is and see if there is a loose wire on the panel where all the wires are fixed, It has been known before that some of the clamping screws come loose over time, (y)
Hope that helps.
seth.c96
