SOLD: 2017 Tundra Limited 4x4 Overland Build
blackoutt
@blackoutt_adv
2017 Toyota Tundra Limited, just over 60k miles, superwhite 040 on tan heated leather interior, doublecab, 4x4, 5.7 liter, 38 gallon fuel tank, remote start, 2 keys, second owner, clean clear Indiana title in hand. Water pump replaced under warranty recently, no cam tower leaks, mechanically sound. Fat folder of receipts for all work done by previous owner, SDHQ, and myself. Located in Columbus Indiana, fly and drive opportunity from Indianapolis, Louisville, or Cincinnati. PM with any questions.
with everything in the list below included (pictures may be missing some things and show personal items that are not included)
Cons: For full disclosure. Pinstripes, scratches, rock chips, mud packed in places that'll never get cleaned out, consistent with its intended use but no major dents or body damage. Wheels have superficial rock rash. Front body mount and wheel wells trimmed for tire clearance. Front bumper rubs on headlight filler panels when flexed, "normal" for rubber mounted body with frame mounted bumper but bumper might be mounted a little high. Muffler has internal baffle failure, still sounds fine but it'll rattle if you shake it by hand. Dash panel scratched from cell phone booster mounted on air vent. Topper color match is slightly off and poorly painted over its original burnt red/orange color. Rear seat aux power ports not mounted yet, just loose panel wired in, I haven't decided the best place yet.
Suspension/Wheels/Tires/Gears/Brakes
Icon "stage 9"
Icon 2.5 front coilovers with CDC
Eibach 700# springs w/ bump stop spacer
Icon 2.5 Rears with CDC
Icon RXT leafs set to option 3
Icon billet upper UCA with delta joints and heims
LCA cam tab reinforcement with weld beads
Durobump front and rear bumpstops
Coachbuilder +1 shackles
Front sway bar removed (included with sale)
Energy Suspension steering rack bushings
5x Method 701 17x8.5 0 offset
5x 37x12.50r17 Toyo RT (rotated spare through for consistent even wear)
Spare tire cover
Nitro gears 5.29 with Auburn LSD rear
Toytec extended rear brake lines
ARB rear brake line and ABS bracket extenders
Armor/Exterior
TRD Pro grille with color matched surround
Color matched handles
Toyota Tow mirrors
RCI raw aluminum engine and trans skids
SDHQ sliders w/ grip tape step
SDHQ ABS guards
Total Chaos bed stiffeners
Expedition One Storm Trooper Front Bumper
Expedition One Dual swingout rear bumper
Expedition One Roof rack
Expedition One Geri Cans x2 white (used for water) x2 black (never filled), comes with x1 valve for gravity fed system
Warn VR-12S Winch
Factor 55 fairlead and flat link
Leer Topper with Thule rack 2x locking crossbars included, tilt windows, carpeted interior
Tailgate bed rug
ESI Ultimate Taper Seal tailgate seal and other waterproofing
ESI Ultra cap seal
Sealed bed for dry/dust free living space
Lighting/Interior
2019 OEM TRD Pro LED headlights + harness
Baja Designs S2 roof rack lights
SDHQ A-pillar mounts
Baja Designs XL80 Ditch lights
Baja Designs Squadron sport R Amber fog lights
LED rear bumper backup lights with reverse trigger and switchpro switch
Max Liner floor liners
Brackateer and Halotron fire extinguisher
Backup camera relocation with anytime backup camera mod
Front camera and spare RCA input added
ICS dash mount
Blue Sea USB fast charger in dash
Switch Pro 9100 on SDHQ console mount
Victory 4x4 console molle panel
OEM TRD shift knob
Salex Vehicle OCD center console organizer
Fyre Flys LED interior and cargo lighting
Xprite 42" Sunrise bulge light bar
LED rock lights wired to cargo switch
FatMat Sound Deadener on rear cab wall
WeBoost Drive Sleek single phone cell signal booster
Always hot rear 12V and USB ports for fridge
Dual USB/Voltmeter in center console
40 side rear seat delete with 53qt fridge (can easily swap seat back in with a few bolts)
Inside cap lighting - color change with bluetooth + remote
Cap hatch glass white LED lighting
CO detector
Indoor/outdoor thermometer
Rear hatch bug screen
Other
SDHQ air pump relocation kit
AFE exhaust dumped before axle (tailpipe included)
AFE prodry S air filter w/ carbon filter delete
ARB safari snorkel
Bully Dog Programmer/Gauges
ARB single compressor and mount
ARB Diff breather
Alt-s diode
Optima Red Top starting battery
Blue Sea winch cutoff switch on battery tie down
Custom bedside track mounts for hi lift and shovel (included in sale)
Tech12Volts Fortin remote start
Wood drawer system, sleeping platform/kitchen/storage
4" memory foam mattress
Reflectix window insulation
Maxxfan 12v RV vent fan in bed cap
SDHQ dual battery tray with washer fluid bottle relocation
24F AGM house battery
Noco Genius 2D battery maintainer
Blue Sea 7610 ACR
2x 100w HQST solar panels (roof rack flush mounted)
HQST MPPT Solar Charge Controller with remote display
Pop n lock tailgate
Alum oil filter housing
Fumoto oil drain valve
Camo trasharoo
Not pictured but included: Iceco 50 fridge with cover (normally rides on the single side of the back seat with the seat back/bottom removed), queen size 4" tri-fold memory foam mattress with fitted sheet, both shown in first post.
Not included: Personal items shown in drawers and bluetti power pack in back seat, although I will work with you to provide whatever camping gear you may need to make it turn key, especially if you're wanting to fly and drive the scenic route home!
Pictures
exterior front
20210626_125338-jpg.605270
Exterior rear (can include trasharoo, tred pros, and 4x water cans - two white pictured I also have two black)
Front suspension (durobumps not pictured but are installed)
20191122_200734-jpg.358291
Solar panels on cab roof rack, cell booster antenna right rear, RV vent fan sealed properly with butyl tape and dicor.
20210121_154316-jpg.535743
Inside cap carpeted with led lights, hi lift mount passenger side, shovel mount driver side, 10x clamps to keep the top secure. The white velcro holding the fan wiring has been replaced with black to blend in better now.
20210121_154303-jpg.535745
Rear switch panel, 2x usb, 1x 12V, 5 switches to control lights/outlets with 1 extra, CO detector, black wired tri-switch is for lights color/pattern/music and bluetooth, fuses on red wires are for the cap 3rd brake light.
20210113_180356-jpg.532316
Full kitchen/bar height setup (high chair not included) gravity fed water by flipping the tank upside down on it's mount.
Front camera view with switch pro, trd shift knob
upload_2021-5-4_15-45-15-jpg.582046
Fridge set on 40 side of 40/60 split, 2 seats in the rear of the truck still
20210228_134020-jpg.552597
Hood bulge lightbar does bright white or amber backlit
20191121_211533-jpg.357571
Front camera, Factor 55 flatlink and hawse fairlead, 12k warn synthetic rope
Rear power distribution wiring, solar charge controller, RV vent fan voltage regulator (so that solar charging voltage doesn't burn the fan motor up), additional USB and 12v ports, solar charge controller display velcro'd up higher on the wall shown at top of picture. Wire bundle goes back to rear power panel.
ARB single compressor, SDHQ dual battery setup with fatter wiring and 7610 ACR, power steering reservoir and washer fluid reservoir relocations.
Rear sleeping area with lights on and window insulation, queen size mattress. Inside/outside temp/humidity illuminated in orange, velcro backed so it can be moved around the bed.
blackoutt
@blackoutt_adv
All PM's replied. Happy Monday bump back to the first page after our return from another successful ~1,500 mile trip.
The rear seat has been reinstalled for the next trip and fridge will temporarily ride in the bed. Mileage will tip over 60k on this next trip. Upon return truck will be detailed inside/out and ready for new owner.
blackoutt
@blackoutt_adv
Back from another trip. Some slight water seepage from underneath the bed rail plastic caps into the sleeping area was detected during long soaking rains so the camper shell was pulled, plastic bed caps removed, everything cleaned and sikaflexed under the plastic bed rail caps, then reassembled. We also got a screw through the center of a tread block and had to have that tire plugged when the screw was removed.
No further trips planned with the truck this summer so it will sit inside on the battery tender now awaiting it's new owner.
blackoutt
@blackoutt_adv
Still waiting for the truck to get detailed so ignore the dirt, but updating this post with some more traditional for sale listing photos anyway for those that have been asking.
Not pictured but included: Iceco 50 fridge (normally rides on the single side of the back seat with the seat back/bottom removed), queen size 4" tri-fold memory foam mattress with fitted sheet, both shown in first post.
HBCNn9RbblsJmaukhhK3bpa7vcpriDHfuDXaLKJbDDVAR82f9AZ6fkTOfiMvJ-_VByYawFELfmQRTnAhoJmYC18G90txC4AeGkbR8eil2ZDc9mzY3QmY3UFFIcCmwFg_gN3NgVzAsSWyVNd_DciztOfezVRZP7OfQ6IUfYtok3M2Vgn-p3VMJ0b4wu4TEFGqRNhCGnutBm7-hqXvNA8lZEenZeeZKvoh3ZCAt79MxIojEbKcQOKEaxt0F9bdUdaoVKJ9eW6U6sSs9ydgKY8PswS9Jm7jpeRm2PZoA8kV6XXxwCCDXohAx57D4xqxGZ5Lmw6BgV5BG7XEcSkjdy15cQk8ePt9hMC_yQ18nd0BxIxxZq_pfhbuveDy21sd5ND4gAWstnjmvVG169PYN4u0SmJl_c86t0lxW5O0rt9KYrVL9SMhAKHwCjt7DXi6n-e-XJyUolQj3qsgibp1wFmAe57apTe9110ZxKmJAZG_n5cb2cSOtDN80zaxbMWSvvuCObDw6klzfIfWWPF5YGcTzvRMkVCgAdAepdWbsLKbblopjYGyMVkmmfY8gNfckKHgvuHrnWrzWsaRagTe5vWHKYdHd6P1ZIYPXvVufz5Ai7OylsvtSLIvHkzQilOqZzaIB0QtHya-Ie2ZC9D0MTXAdRs1tNVS_ZVV8g40Y-qgTQuHtmPWIbyvgzrVb73U6qaA4tjoyAP_UzAXtpJ7DhfeVCM7WQ=w1204-h903-no
gf_27o0Bat8B_4Mxnx0rd5Z6szE5VNzfhshRzHN2ArFbxAGlUmz_z3c1ZpQHrWU80iuLzUYw2U18RNVdi42YAQJVp7AAL9Jzru4rb70rqu-4B6-TPDf6d_iHD9ipMQP6_vqpQMWRyydHfc-hymQCQZxyBzmHR8tlV8rHP2m-SAo4MTnSLMVGPLBJj7l5RVI3KvEC-bdVOQGrLzhvYArPwn_Hii-RYYCS4nPez2ui8_kynWKL2Wc8bykwH_Y2W6rP4masJ1hFhG7sFNgGFXE60MrABJ3nTZOTTf7LpHxLbuok5BqpAt6fVUgoKxz_Gwgz9CosxATuMb_FuY2qO6erTuwzDeSUaSYyEm7TjPIL6pyQEgFW5F0K0iYZt_PR64gx-LLeAsywCnRfCNa2uVmd2vvUpWJmtsAF7IUxr2nZpwtiqHXrw3LLg43f3v-zuXXgMW8ZSOLmgCgRkfkFVL3ufZ3wudBsSuOoIdRqxtJtI52niq-lfbLxrIkQQHt45wVBdEoFrAzR5jV7cQxKWX2V6qI_T7bldOuO8ALOVqrCsNqz0dG1lRQQqTwQHgkO-xYyAcYKhHG7Vguqay99KoFVbFoxVsnCNBl2URfkYmP9WYDOmwvZpxhEpKOCiC08gtBKlieYEcPOqbL8HKhsR6szykMLQT0TbCOdeycm5sEboAYcmFbRLBhmfj1Rq2Trv5A12HePBzmNOjGQkIkElM2CNmgpVw=w1204-h903-no
kQWFXm20-S1q_yWDr5ddNoUoWWySa34LjXyTOvzDlOTjn8LuCrvjevk_9qf1JRM4_B2yPGeNJoGd8XPCesBd_7dzCb8By1HQ_bAvp3uvSZsD1f0U2DEbP3PAqF63CwCM3uCvpS6IvTWnrExVziS1aBzifQQGVkwLpKDXDMGtua6WD5s66YSDC_rZqcasWXv-OsdAKZwCh7IqEY6PbjGJdNtRK1aHOpwvSwy8RqTdxiyBJO_gfbOGazkFWMjARDZktQssRqNn26xsG26NCZpKtN-YNiGwR2GUhSRknhHzvlVs6YrhPE4z0hV9-fmJqgrHUTMsHzJIq236jJzR1tj9j5Lg8YKoWqDM0NEjEb5eVzMw0N_7aH2ByUeAV2SBWmoWdB3cPysD75s8rTq3QkIsUh3T_jYeBEZS7HHhX6BZ8h77cvZ5cxrqaM4-mzjJaGTMj408IBdCz0Sq6kkOHWQnoNSejZo0cdTFRXXMSKHoslbQk2WRuVuh2l8nHMwZoUFmrO8oPpiEa1VRshXcp7Cul6niN6d8D4RgxjHkHVZ7_MmUzhfhXS83ZyHMef3f5Fj4Ruo7UCwcQLpyvreFIcqYazQrB6K3dclbEosPCPbSm6X6_v_RdQhW4PjFwBcFprQObfcTg1EmtB8QVcu2afS6XjLsBDGraNzBTkiWAf7Rf4yJYaNAL5c5gKh0Um7vRQcSLT5FKhdIcKiG338UJs30abLPuw=w1204-h903-no
cTP3bQC3r-FcQiVtW5M0AgsHqvIo7ubObMVeAH95jI5DfircjJUDnc1TXAEQk6-dAffbfTDm_oN6eMKtbHcYP1nL0velAFPVZkUoHE2L3H88_qrlgh5ftvo2w1gU-4TfB-h_HjOsc6wHxQVT1vdfZcsYi6V5Ct8VWZCn_bGhCGOsk3E0s4Q6GUguXwwH4BgCb05Z4XG4EClUE_Ofy3OGmRjpfqISXZJds6qd8RbBMnZfFYB-5HGcyp_WVzPMRsKRRjq9ua4lCDhm06rSGlLuMBySRRRE3_iZcVwPTNARXD4g4CmRIc2rpZZ94T-Tq369r-Tbaa3PtnQIu84A21L-eKF7BKYvd_3Go9JRGjbCYltFTV38BZDbmmN5obbeIKw--n_wiGHdV6mhipVCx_Bbbv5Io8YpjL44pN6K0IYw2AYRxpJ5kG0hhBr3wBHx1tjtryEn9nPmkyWvXHPCbZmlT41vn1AVzwhV6PNWweP7XWRCUlVPUKYx71yxQTN1ttlRQ-VOpgx9q1IKWJwI4NO3SemHZ9Sp4_LQMBT-RDc5O6KfRqKRf94_BQGlcvz4N4XjGCF8w535GLm1gEuWKcpLEdJB5mA5v-SVcHJ7K8kZvu43nRgKw9PKLQomUOe1wRa8PYpd9ni_FIDrpyb2i_IVFB9YDLWMZrJXIEdGvTfJ3-hWP1upFEnwN--nCJrbbpXbDurEA8wdGSgG8Oia7awgIs70Yg=w678-h903-no
OmK6ihBZg_7aGduV7tZ-l6dhE2OZLvwKMpu4qWPIrPubXJrwBh5OGHw1kmU41dz8WtkZl4BGaykVenEF9fufmMi6UeSj5Es9sG-yfRrSP-cVwoLyZE9sctnB3-5lyz-5I01IoCAI6eHTd5UVV5THgFO9KioBR1FdI0iFB3WpbfHwPjjYXBh_LBqX5XRxasgry1YSZ9tD9SX5nim3mRQWWRdMkGp0VOKrqljqRojCeDJXK9o-Jd4HLL1clABr6MGsBSqGE3YP76LG70SOdHtddvt-dPLJV2L-URnMQDED-Yn8d0ffmZJ1ACSwRoVeVhqStTxhD18n7Fyjyhyw_FnVvjVe4OskT5RKOPFvISzInzN1FDKxpadfbhZrEYpZh3buLXyJncMAgPjYD86EiSFtCg729dFtC5ji5rJaalRJQF4PtZzohi3kbxlcYKPQ9Z7o29oXlatQ5msM31TcZRDQ39L6qDxCu7UxhT6xmD6DJZWfapxUQanvcMV_JAORgvi9ORsARM4ZIpf3xDcEnclkyAIHlBI4enYgqLnE5uw2QrXKVirHjwdGa_UcMwviJe-SXns1s4EXZJLGYPpbWd21jdIsIZnHjXJSA_M9p1PMRCaCu_qvl__ekGTtZmZcHKwOycIag9uhQkyR1kdBXj2G_cZNtb-Wkvt3U-twPwKkQdzYzZs97ffUX-bHLlTRzhNm5-glTZyG314MtsT458FWDx5UmA=w678-h903-no
oaH0AwLBUs_igqzuS4GQ5ODzNznvFc9on2YR91cEO5Tm8GAxJd1wTSp0fMqZxTDTCLsz_FOQzxpHwEiB_Tz3_EDIG5PBYX1OoDs-il_0cUEzFXe414ej3UYPyb9L9mKTEBlh1P0U9kmAWZ851RnB7YT4NNvbmR9p5oGyEOK0hnnloYrxRxvF_Cd5VUlFghgfO9esFGJ65S_e9toXpdsuuIVr036s-dK8yedJr3I2TqO9c3RNGXLgAuPPUa7GV48z8rkV4-KyziFmMeeyiLla6UiIGU3l-BuT2ZwhYvsyUZ5-1MEcaeP53Ff16R5_vXPmmP3mkcbtE1GbclST7y_5Al1o7wAvqNA1u4R9uMmogmEQDLb7nnKsdk1jNTyx10XOhJEDIZncK7-3lJS7vZ37T0shD63s-vCBOgaMab5MUSj20yWVn21ziKFxaXMxV4svoVeiUYnIJg0XwTwr3c2Xpxj9PWJNshGD5h31r-JaNKZ1VOZ7eeSqtEGT9QVRhNBN1M4DPWrkCNiunAUZxe-RdeVmZ_ZjKRV-Qk83mXFLkKTmdSx080PyNq9tt7ucyO6Zb4istUKYw95wVXCnYrS4I7Z7yUjeiNy8OCI0XV7Z6KOr0CuHsJNf-iqryaStU0n5EPRyOa-2n2Rvlft3bbtb2xjXpqd7OaXcM7gfN4-3YGcdZg3dD6Q9NPBPjgFIU1pccc8uzNfnj73eY7LtJ-s7QJj8nA=w678-h903-no
c1nX4IrQEqH4NzCJlUVsEVihsu3Vu98UVFJZ3UhqtOhd-FjMk2ZxQRMBsWMgNiQSYFFwx6oJ9R1q_B5B1GbkoWwg3Oqd-iQNRsTAXgCf-0NFEJNiM9r1fdkOBLUuBP3rl66z5lezcwTCcY_oyOJr4gEqyVD3g6xSIJ9Dv0FmqMUS5A69_qjeiFqv5LXFz-i-fNZUVRSCPsnGU0AfYNr34AGChMw49In3_bfqUPPsDQsokep7Ft5ihvGyb0-Kl1CD4rJzKTH2MFv1x-MStcu_qdb_ywK3j0scxzqFAsk9ZjduEn0wa2J0oEZQAatoPR7h4jfd8SlyLodn9Q-3ZOggekBskB9UXxeWUMNDPGxoeVUO_Ui-5gh78e-Ld2X4dDrAf6f85I8dCuKltOFf5uRzgGqzxIi-3mbtx12BaV3kglJwxp4XEXbOYGMpr47ycx3_U0I6XDwvTECaOnwFlbMEDREP64HHiZMzCZX3Si-UsQy6Xj3kZ1nG7nFCn9JOGVMU6AEk33QzkHuNZvaaM5nnyqI5vgxojmZ0lHVeiNto8ZiIdDhnWHun3ThWiaZZU5QbYmLFg4KzvVhc72r4054qHLtSm_CRYJY-1qdHxvZtx_XCoXSnLFzteNjhFWLyN-f1lSmdtoMdePc4LwDJJI-5eJYAlhi0Zd4FiK3lTPUithZo10JV8Bu9sPuuYTXguloXPkWtpqBD-syotzAum6yMMKG0ow=w678-h903-no
KHdWPp0BM9MpyYQzwQ7BxsonsZQbFyrAKSffX_MPBKLmIL8y42N_FCygQ3y-pt4xjlbBwhKCH83OlRd_xc8L3rXkL-vkJrdSp_5GA0V2clCeNeiEm2sEN5VjCf6laJPfqlj4d8vTnGPIxzUzRalxnuX9QwXVW-Dpr0KHKabA_h3x-cEf11MYZBZ-yVtTr2fwv55cMlepCJrJtKfowQnprU3DdjTrRhl9j3elc2xmrlMU95liYT1ykG4FpXRecJdmk5cGY8a0fKB0DAi-86kUpsrgRV-UtDueqqIY7YCT8YgbvNax54WnmMJPvGHXT3HzSD-aHKKncHZKEe1ZJW3xJlPQl5h7Vrht6SbQ4VQTLw6YZUB9wqoslYZDjwj2Ikwb6X14f57OQ6tPU_N775iExpmI_QrFG5LO_8vaE2OQ-YtDJ8jGzSbO-fBjbg-XnZqJZF4eUZ5rs-ZGdtjjeZ_wKj7PwRELYSbtd76OWi3iPJIz3qN5zC9KcK22o35z9JSxrfvsMS5lUm3yIdzrWx93c918-49cZSqiI_8EBvkPWbEeVcPPhpGe7VV9Q2M-M1WvE9Ammo67z0B-kbiwq2YWDNKfSTs-KkL2KxG-6WVRchKk3N8xiqahYnFUMyONj5R98VtqGG5Y1omAALidfNX4DnL5HXprjEBPQnG1iBYdgQWVfmqBdHK4hQMjanjTLMpx4YGwHXMI-f6uWCP0m1Ff-IjrOw=w678-h903-no
So-XeXtMdcK-zsBXVYGjM4CHvzWGYAaqHPNql-85qqN9hXd9W_ihboOCh_BoTmqZK5vGw8SNPbGaCBlSxEHpYD-sIR7PnGpwZXKvlF1iQqXaXZ45sHhjC9ihWPuwyc7RId_87hFf-IZNOvo72PEwTXuu3XrujIXcgulRmk81RLKGn9DR1pnn2vdPQifyaptkI5nuJgBntPtml6Y8_2mIUMoBXYnT5tbkbUa85Ul_qQs2uM3O0-KFqvl06w1pPCw8oLyRY5MMgkpC4LFbEZJCP2ohit1SNdXJn-m0qCqSt8wRApTHWZ8LmNgDBw3dZVLdwS7TCTMW0pwJvn0rsI5iCZeEdV_vDtJHmhPj-Ey5H8RkP6ypCbg1ZC1Llh0FA8OhBe9exu-C7RnzXhLuMqqEO3VwQdJTh2u_vWZNQq5Cn8m7CV73i_LRfQcwl1s8CUqdPqXmrqeC-dKXbZdQawUPNCD-fTwle3UAcmxfEVYd-oTlZNhXoR5_hzE0ullBZqx6AX1t5vtyqjlYlBW40fQYMRwY1msA43DMpWysPyLSQJAd-t_RsYiKomlgXr8IL1oR6VmGeBeHFH-HoiDs1EzTZGfkY_EjiaFEJ45N17lhiYyGZiosH_qJ9rmL7a6fL7sraird4XViuNMSJJwXdrxQA_v5SOl-n4bkHwxpUJJPda3h5Fhr-JH73aVe64exKLk0liw_PRQ78PInMy1MneAW-TULMg=w678-h903-no
JupojxFzOtrcUn4eMV1bV4C-PGELA0q-jMVgddVAcrZPiMiyhxtl4QYLswPqWZodnbuk8X-KHg-bYccH2Xl0ce_KDHf5hsMiVBsPK6S_QkStpOJzmnLWv4uZDhTBRH94odSr8F0CYwtQLBovko7ZFx_OVERsSjRBWLYMHEJt4wegiWX7EWjCbP7lifA-UEMY2pdD1_lftvxhGvATR0DKnrPRzr358bDGtbp7RrAd3LNm3uTBc-Zse8zIorZcnUPs6N7Sbc_W05B0loNOnlCjeuGK2-LCcnKU12qcLpVzL5pXGnYNwX2JHU8PsF7gv3bha9WdFt6sDe1mBBBO5KeO6bPV-k46VLXyRIXT0FjYpQBW9sqA76O9o6GlGmVzgTnyv35fjldVihOppfL2gEJJL315cB3d-q5PbgvggEMVQezJKhExLt2eawKYiaKVuQX0O1uv6NVgoEfWMlP_QawRnUXVHCMCpIfsEFw6zCswkz-8uMFg95su-eP-Fk61GfNqt9Eb0ArNa8IAxoqqdwt9JxRkYSWagUCEFTqZygnsqEq5lCYxHmO2uqxDWbOOjm58CyCSRjNl4ShMAMOr0m1au6hsJaol_3YqZ17if5v4oQD3rn74_kuEUALNj-VuhX9ngRvLEntbH5b2eJpCRSLAnJG2-mrwGeI3HSAfw4-qnlIDJAnijaerOJYUc-nnG6lRc_FQKatXUAefwpPo19n59xWlLQ=w678-h903-no
RFIoVLS7dsn5kfl2scXb51lnP9N-glcraVGg9ZyCpiAbrWwJ170RLPqq6yBQy7S9egUsOfUMVwCPGNi2GlIdQKbJX_WS3xm5BeJ3EZQdHTEHPv1yaTuIvkNLkZCAMQ_nfpdK_MKBTwLsHhRSB6h3OowRMgoG2pwj1o7I-ejDKUj2bLPyteR-t3OHCUObTPIFoIppSnpqYXkXQ3kX_6eC8SetOCF2HzFiT56459wlUe7dETSez55iu-IIjJzAaoKm3zzUibe8Ggqwi5kNj1v5YhuyB7h8AxHqLj-mZV56EFCubGgvukfnYto5xXxNH3QwgTfbs3enFurgBK83f32F3NXo9dNlCkTC86BhRT4clUkb-8ht3MDWZIdzOlENg-tHju2K5zQZ5Ieo4HnT5kaOVi783G1MG0KPj0Pdiw_Vil_ky5l1HgQxXK3NgbI-zNP46mF8iQ1RcYluBrPIFDJhdDqn39ZOGjWclJRLYyAHOrKxkqd7Ox2RWbqulEqomKz8qwrVYwNwxA_6y9I0-h4ZGPVc-1HoHQWnK0v_gaxjZ1K-thN_42kJSKZHT_7mwSRoUn7gcQ1-ik8Uqt3wULPsO8DsI0qCj6Xz1v3vI5-y1878fy3ZfN6sXFezKt3mDK1eZhe1rEe6KCZEK82DCWwYpKJU_54C116gex1ctPyYEnHBVsrrncsEmWZTsaOB7CzLHVzKpJ7rmgMc_muQsQIVueAZCg=w678-h903-no
blackoutt
@blackoutt_adv
Last two posts of photos aren't working for me.
What's the payload and how much weight have you added?
Shared album wasn't really shared after all, fixed. Thank you!
Edmunds says payload is only 1,580 lbs for this configuration? Seems under rated, same as Honda Ridgeline! Never weighed how much has been added/subtracted along the way.
I’ll second that the photos are not working for me on last two posts.
Fixed. Thank you!
zhukoveli
