Sold: 2009 Land Cruiser 200 Series w/ Mods_North Carolina
oneenv
*2009 Land Cruiser 200 Series
*138,682 miles
*Super White
*Well maintained North Carolina truck
*Currently located in Asheville, NC
*VIN # JTMHY05J495003688
*Title in-hand
*Clean CARFAX
*Modifications:
  • Icon Rebound wheels in titanium x 4
  • Nitto Ridge Grappler Tires (285/75/17) ~80% tread left x 4
  • OME Medium lift
  • Baja Designs Squadron Pro Ditch Lights
  • Redarc Tow-Pro Elite
  • Blue Sea ML-ACR Dual Battery System/Relay
  • ARB Twin On-Board Air Compressor w/ Pump-up Kit
  • Trekboxx System Alpha Rear Storage Drawers/Shelves/Fridge Slide-Out (complete system)
  • Dometic CFX3 75DZ Fridge/Freezer
  • Eezi-Awn K9 Roof Rack 2.2 M w/ Table
  • LED Interior Light Conversion
*Also included:
  • Eezi-Awn Series 2000 Awning. Note, last used, the awning was not retracting as it should so we just carried on manually rolling it up. I suspect the spring recoil mechanism needs adjustment. Other than that, the case and awning are in great shape and have been sitting in the garage for the past year.
  • 3rd row seats
*With the exception of the roof rack and awning, all modifications were competed in the Summer of 2020 by our local vehicle outfitter.
*Truck will remain in the garage until sold therefore mileage/pics/etc. are an accurate representation. Happy to provide additional pictures upon request - I'm working on a sharable link.
*Asking $42,000
IMG_9169.JPEGIMG_9173.JPEGIMG_9175.JPEGIMG_9176.JPEGIMG_9179.JPEGIMG_9180.JPEGIMG_9183.JPEGIMG_9205.JPEGIMG_2104.JPEGIMG_2108.JPEG
DailyJeep
Looks like you already replaced the radiator with the newer design. Any other recent, notable maintenance?
Great looking truck with quality build!
oneenv
Thank you very much - that means a lot coming from this forum. Yes, the radiator was replaced as well as coolant plate. Re: larger service (outside of standard oil changes which I'm religious about)....
113,000 miles - MISCELLANEOUS MAINTENANCE - REPAIR, J05 - REPLACE WIRE HARNESS, BRAKE INSPECTION, RADIATOR, COOLANT ENGINE - REPLACE, ELEMENT, AIR CLEANER - REPLACE, MISCELLANEOUS COOLING SYSTEM - REPAIR, BRAKE SHOE HARDWARE KIT - SUPPLEMENTAL, PAD KIT - FRONT (W/O HARDWARE) - REPLACE AND MACHINE ROTORS, PERFORM COMPLETE BRAKE FLUID EXCHANGE SERVICE, TUNE-UP - BASIC, CUSTOMER STATES
120,000 miles - OIL AND FILTER - CHANGE, ELEMENT, AIR CLEANER - REPLACE, NORTH CAROLINA OBD INSPECTION, MISC. SHOP CHARGES, PERFORM COMPLETE POWER STEERING FLUID EXCHANGE SERVICE, *** OPCODE NOT ON REPORT ***, DIFFERENTIAL (FRONT) OIL - CHANGE, TRANSFER CASE - CHANGE OIL, DIFFERENTIAL (FINAL DRIVE) - OIL CHANGE, *** OPCODE NOT ON REPORT ***
DanoWall
