Ground Clearance Needs
Smileyshaun
OP specified not rock crawling. Let's give each other respect of assuming that unless explicitly stated none of us are new to this lifestyle or naive to the variety which exists in how it's enjoyed.
Outside of feature trails which exist essentially for the challenge itself it's difficult to find a legal scenic route anywhere in America that calls for locking differentials, 37's, any of that stuff. I scaled back years ago from what I had been building because of this. These days domestic "overlanding" pretty much consists of touring America's vast array of locked gates and no trespassing signs which is done as easily in a Miata as in a Unimog. When one does find a legal route - again one which is not explicitly a feature trail that's kept open by deliberate stewardship like Rubicon or a component of an OHV park - it typically conforms to the highway transportation standards of the state it's in and will have been graded and widened to permit administrative/fire/resource vehicle travel.
I think different areas will require a different rig I’ve beached a few rigs on a FS roads due to lack of clearance , especially when winter rolls around and things get sloppy and snowy a couple more inches of tire can make a world of difference
D
Deleted member 9101
Guest
This is exactly why I have a 2wd truck on street tires!
phsycle
… but again, I haven't really gone out and explored much since purchasing the truck...
With such vastly different terrain throughout the country/world, what works for one may not for another. Best is to just get out in your terrain and be smart enough to know when to turn around. Then modify as needed.
D
Deleted member 9101
Guest
Low profile tyres were never good for off the black top. If that is your only option it is the wrong car.
Cheers,
Peter
OKA196 motorhome
He most definitely does not have "low profile" tires...lol.
Like hundreds of thousands of other truck owners I have 33" tires and 20" rims and my truck has zero problems.
Grassland
Pricing out tires for my wife's WK2 and $120 per tire difference between 18s in the O.D we want and 20s.
With the state of our roads alone I'm leaning towards getting 18s just for that much more sidewall
Peter_n_Margaret
Depends where you intend to drive it.
33" tyres on 20" rims is way too low profile (in my opinion) if you need to get through soft sand etc as we do constantly in Oz.
My own vehicle has 37" tyres on 19 1/2"rims and they are not ideal. The replacement vehicle will have 37" tyres on 17" rims, a better proposition.
Cheers,
Peter
OKA196 motorhome
D
Deleted member 9101
Guest
Cheers,
Peter
OKA196 motorhome
drive down the beach all the time....zero problems.
D
Deleted member 9101
Guest
It's not a huge difference in ride quality between 18" and 20".
Buddha.
Finally in expo white.
My summer tires are 33 on 20.
My winter tires are 32 on 17.
There’s a slight improvement with the 17’s.
I’m on E load tires running about 50 psi.
V45W_Proto2.5
