Worth converting this 2wd E350 to 4x4?
socceronly
I am hoping to use this van in the winter more, and on some rougher FSR & back country roads. This vehicle would be used a lot in British Columbia and making a trip up to the way way north.
It is a 2014, 78K miles, 5.4L
It is a 12ft box truck with a kickover above the cab.
From a cylinder misfire, I found that cylinder has been repaired before. I guess it was tapped out and fixed in the past at some point.
Is a repair like that a red light for not investing in this van, or is there any other reason not to convert a box truck like this to 4x4?
Otherwise I have really enjoyed it. Would just like to get out of RV parks....
Appreciate the input.
Thanks
JM
Raul
Pictures will help. If rust is not an issue, it looks like a great option. Plug issues were more prevalent on older models, I'm surprised that happened on a 2014 with 78k miles. I did my van with 209k miles.
gaetzjm
Does the Van have a dually rear axle? You could first consider good tires, a lift and a rear locker or LSD before converting to a full 4x4 system. A 4x4 conversion is spendy unless you DIY. It also depends on how rough you want go with a large vehicle and in heavily forested regions like BC, overhead tree limbs are often the constraint.
socceronly
It is a single axle in the rear.
The conversion works out to about 14KUS.
The rest of the vehicle is in good shape, BC vehicle so little rust from salt.
motovan_mn
If the rest of the vehicle works for ya, sure sounds like it'd be worth it! Is that $14k paying someone else to the do the conversion or doing it yourself? If the former, sounds awfully cheap...
E-series box van would be my ideal rig, if it weren't for that pesky little toddler that needs to be strapped in to a car seat somewhere!
Mickey Bitsko
How about you finding all the parts, I don't know but I would think the front axle assembly transfer case and linkage would be very similar for a f250 of the same generation.
I don't know about the labor.
billiebob
I'd stick with 2WD but look at lift options. There are a few threads on this forum of guys who bypassed the 4WD option and why they stuck with 2WD.
But with low miles and a clean E350 you have a good base for a 4WD investment.
Mechanical issues are a factor with any used vehicle..... do you own it ??
turbodiesel
Worth it? Maybe, maybe not. It just depends on where you're going and if you are more likely to self rescue.
My soft list:
  • Pro
    • Lift or 4WD let's be real, just looks great!
    • Wanted the challenge of doing the conversion.
    • Gotten stuck in mud and sand (CA & UT)
    • Needed to get back in the woods for outdoor adventures (Climbing and alpine requires going down some craptastic roads.)
    • The mental ease factor. I doubt I will use it a ton, but just having it, along with recovery gear, reduces the trip stress a bit.
    • Snow never really had a problem with snow, just go slow w/ chains. I imagine I'll find a case where is comes in handy this winter.
  • Con
    • COST $$
      • Lift is probably 1/4 to 1/3 of the cost.
    • Time
      • Lift is much quicker to DIY. Less actual work. Less Parts.
    • Did I mention cost?
Lockwoodjd
