2009 Nissan Frontier KC Pro-4X 6MT
westracing01
Don't be afraid that this is my first post. Long time member of Nexterra. Was told to post this over here as the truck really is a good platform to use for Expedition wheeling. I can get more pictures of anything you may want to see.
2009 Nissan Frontier King Cab Pro-4X
Black
4.0L Engine
6 Speed Manual Transmission
Basically every factory option available in 2009 except Nav
I am the original owner. Bought it new with 12 miles on it. Current mileage is 178,000 and change. AMSOIL fluids in Engine, Transmission, T-Case and Diffs since 60,000 miles.
$6,500.
EDIT: SEE LAST POST!!!
Located in New Milford, CT
Engine
Injen CAI
Plenum Spacer
NISMO Shorty Equal Length Headers
True Dual Exhaust (twin Borla’s dumped behind the cab)
UpRev Dyno Tune
Drivetrain
M205 Front Diff out of a 2007 Nissan Titan (3 Rib design)
OEM Titan Half Shafts
Stock M226 Rear Diff
ARB Air Lockers in both
4.10 Gears
PRG Short Throw Shifter
Suspension
Titan Swap (PRG Upper Control Arms, Stock Titan Lowers)
SAW Remote Resi Coilovers up front, FOX 2.0 Remote Resi in the rear
Alcan Leafpack
Fred Goeske 2” Spacers in the rear
Heim Steering Upgrade
Armor
Full Set of Shrockworks Skids
Shrockworks Front Bumper with LED Fogs
Shrockworks Rear Bumper
Shrockworks Sliders
Wheels/Tires
5 OEM 16” Pro-4X Rims with 315/75R16 BFG KM2’s
MISC
ARB CKMA12 compressor mounted in toolbox with 5 gallon air tank and quick connect
Rigid 20” LED Bar up front
Rigid Dually’s reverse lights mounted to top of bed
Swing out Spare Tire Carrier with Jerry Can holder and shovel mount
Custom Built electrical system to run all that stuff
Odyssey Battery
CB radio on 4’ Firestik
Spare front axle shaft, spare heim joint, spare rear driveshaft u-joints.
Truck is in perfect working condition to hit the trails. Could use a brake overhaul, new heims in the steering and new coilovers, but it all works as it’s sitting here right now and none of that is of immediate concern, just something to consider down the road. Truck has spent its whole life in the NE so there is rust on the frame and the bottom of the rockers, bed corner. Nothing rotted through but if you want it to look all shiny and new, bust out the flap disc and get to work.
Forgot, the RR parking brake is nonexistent. Not that it matters, the parking brakes never held the truck from the day I bought it.
I love the truck and she has taught me many things, but the sad fact is that I don’t have a lot of time to wheel, our club lost the land I really liked and I have other things to spend money on. Clean CT title in hand.
westracing01
Don't be shy. The sale price posted is just because I had to put something. I'll listen to any reasonable offer. Every service I've performed since it was out of warranty I have, with part numbers and dates. Truck just passed CT emissions. New clutch line two years ago, brand new Odyssey Battery this past winter.
westracing01
You can't build it for what I'm asking, and certainly not what I'm willing to take. Drove her to work today. Ice cold A/C. I can post pictures of anything you may want to see.
Not in the market but this is a solid build for the price. Very capable.
I have a CC LWB and sometimes wish I went KC when I try to do a u turn haha
Good luck with sale.
MG99
Every time this gets bumped I keep wondering how it hasn’t sold yet! Someone buy this rig already…its awesome. I have a truck, but might just buy this one for when my kids start driving (in 10 years).
westracing01
Final price drop. $8500 OBO. I did take a picture of the rear frame behind the shackles and the rust is worse than I thought it was. Would probably need patch plates welded in there. Picture attached for full disclosure. Both sides look the same. Rest of the frame is surface rust.
I will give this until our garage is built then it will come off the market and I will rebuild it. So, any interested party has until the GC finishes. I estimate that to be about a month and a half but it could be less, could be more too. Slab was poured yesterday.
westracing01
Unfortunately it is what it is. Once the garage is built (GC is framing it as I type) this will become my winter project. Sand, grind and repair the frame as needed (actually going to hit the bad part this weekend hopefully and see what's really going on there), paint the frame and fix anything else I see.
Of course, if I sell it after doing all that, the jack will be going up. Obviously the current asking price is negotiable. I've received a $5500 and a $6000 offer, but that's too low.
The ARB's and gear package alone new are close to $3K before install. I have some other random spare parts laying around too. OE tailgate, real wheel bearings, OE air box (good if you ever wanted to do a snorkel setup) and probably some other stuff laying around in addition to the spares that are listed.
westracing01
Update... Again, for full disclosure...
Broke a brake line last Friday, so had her taken to the shop... ALL NEW hardlines installed along with new SS braided lines on all 4 corners and two new front calipers. Any brake issues she might have had are now dealt with.
As such, the price, while available, is no longer OBO... It's $8500.
westracing01
Siding is going on the garage and I'd like to buy some new toys for the new truck along with some stuff for the new garage...
$6500.
Has all new brake lines on all 4 corners, new front calipers and new front brakes. Clutch line replaced 2 years ago. New battery this past spring. Rust on the frame, rockers and bed corners. Driver front bed corner rusted out and fell off.
Drove the truck to NY 3 weeks ago and camped all week. It drives as good as it ever did. Has a heat shield rattle at low RPM but that can be removed. It’s a trail truck and you simply cannot get one that can do what this can for this money.
Petersmithinak
