SOLD * 2018 Four Wheel Camper Hawk * Portland, ME USA * $22,500
meekjt
FOR SALE: 2018 Four Wheel Camper Hawk
Description:
From the Factory
* Side Dinette with Swivel Table (Folds down to bed)
* Thermal Pack
* Propane Furnace
* Two Propane Tanks
* Two Powered Fan Vents
* 160 watt Solar Panel
* Yakima Roof Rack Tracks
* Silver Spur Interior
* Aux solar panel input
* Aluminum Jack Brackets
* Mechanical Camper Jacks
* Fire extinguisher
Add Ons
Roof
* Yakima SkyLine Towers, Two 80" CoreBars, KeelOver Canoe Carrier
* Two 80 Inch 80/20 bars mounted to Yakima Tracks
* Solar Panel rotated 90 degs allowing battery charging with canoe on roof.
Water System
* 35 Gallon Fresh Water Tank (Custom Commercial Grade Welded Plastic)
* 7 Gallon Grey Water Tank
* On demand water heater (Propane)
* Water Pump (SHURflo Aqua King II)
* Sink (Stainless Steel Marine Grade)
* PEX Plumbing (1/2 inch)
* Outside Hot/Cold Water Hydrant (Residential Grade)
* Outside shower head with quick on/off
Electrical System
* 100 Ah 12V LiFePO4 Deep Cycle Battery (Battle Born, 2021)
* Victron Energy SmartSolar MPPT 100V 15 amp 12/24-Volt Solar Charge Controller (Bluetooth)
* Victron BMV-712 Battery Monitor with Battery Temperature Sensor
* Refrigerator/Freezer (Chest Style ARB 50 Quart)
* 6x USB ports 2.1 amp with switch (Blue Sea)
Miscellaneous
* iPad Mount Over Bed
* Hypervent under cabover part of bed
* 80/20 aluminum framed mount for sink, water heater, battery, and refrigerator
* Factory battery compartment is now fully available for storage, LiFePO4 battery is tucked in front of refrigerator for better weight distribution.
* Anderson Powerpole Plug for 12v electronics
* Waste Bin with Pockets
* Paper Towel Holder
* Tie downs next to window
* Backup carbon monoxide detector
* Thetford Porta Potti
Price:
$25,000 OBO
Known Problems: None
jadmt
ignore button user
just doing the math it would cost me about $1500 in gas. If it were $20000 it would almost make it worth it. Just out of curiosity how difficult would it be to remove the water system and put it back to stock?
meekjt
Water system is super easy to remove.
I have a deposit on the camper, will post here if that falls through.
darrylkd
