Ford F-250 rear sway bar onto E-350 Ambulance
Bikersmurf
Next Ambo project. It came off a 10.25 Sterling axle in a 1995 F250. It looks like it should fit my Dana 70 axle. It looks like it should be able to connect to the frame with a couple custom mounts/brackets.
Being a 1.125” bar it won’t be as stiff as a 1.5” Helwig bar. That doesn’t mean it won’t be more than enough. It has 4000 lb rear leafs, and sway wasn’t bad, that doesn’t mean if wouldn’t handle with one.
Bikersmurf
Looks like the bar is a perfect fit. The bracket that attaches to the axle will need to be modified a bit because only 1/2 of it will sit on the axle housing. I’m also going to rotate both the links which connect it to the frame 180* so they don’t interfere with the frame. Then all I’ll need are a couple brackets with tabs on them to attach the links to the shock mount crossmember.
What I like most about this bar is that it doesn’t hang down way below the axle. With +/- 29” tires and a Dana 70, the last thing I want to do is loose 3-4” of clearance for an aftermarket sway bar hanging below the axle. Like this one, for example:
Or…
Bikersmurf
I don’t have a rear… only a front.
Can’t say if it’s an upgrade to what others came with. All other factors being equal, a larger diameter bar is stiffer. That said, the shorter the lever arm, the stiffer it’ll be. Also, materials will make a difference.
The only thing I can be certain is that it’ll be stiffer than what came on my rig (= nothing). I’m also quite sure how the 1 1/8” bar will be stiffer than the 1/2” bars a lot of new trucks seem to come with.
iggi
Ian
Mine came with a rear sway bar, the handling is pretty damn impressive for a 10ft tall, 9500 lb box on a hard rubber hockey pucks. I always get a laugh heading up twisty hills when other drivers start piling up thinking I'm like the average RV and will be slowing down 20+ KPH, and I don't even take it off cruise control.
Bikersmurf
Here’s what a stock bar installed looks like:C55A189E-86F0-488F-B5EE-1ABAA8357D68.jpegE7E6C848-014C-41AF-9E39-6080A155EAC7.jpegA68B6D30-9FA2-42BF-A261-66E3C3375861.jpeg
Dana 70 housings don’t extend far enough for the bracket to all ride on th e Housing. The frame on a cutaway is also wider so I’ll need to adapt that end also. The links come up inside the frame (rather than the outside).
edit:
Note these pics are an OEM install of the bar on a Sterling axle equipped F series truck. With a truck you’re able to buy all the parts from Ford and simply bolt it on. It’ll work on an E series, but not with off the shelf parts.
joeblack5
Thanks for posting .. I found our bus on 19.5 tires and 9800 lbs also a little wobbly in the back and was looking for options.. this seems to be the ticket.
Thanks,
Johan
Bikersmurf
Thanks,
Johan
I’ll emphasize this isn’t a direct bolt on with a Dana 70. The brackets to mount it to the axle will need some loving, and the frame end needs to be invented.
The sway bar appears to be a perfect fit for the axle. Since the cutaway frame is 6 or so inches wider, it needs custom mounts there.
gp01
