LR3 max tire size, if EAS fails
VET LR3
Anyone know what’s the max size tire that will allow vehicle to be drove if the EAS goes out and you have to ride on stops?
douglastic
Up to 31.5" for sure is drivable on bump stops
32" is the grey area - some tires seem to be ok, others not so much
Larger than 32" will not be drivable w/o mods or problems
protohyp
we have built bypass valves to fill shocks manually in case any part of the system fails. We also run Arnotts that have a check valve that will hold up to 75 psi of air so in theory you should never be on bumpstops unless a severe compression blows out what air is in the shock.
Of course if the bag or strut itself goes we carry spares in the rig
