Just my 5 cents, I have a planar portable heater mounted on the outside of my SpaceKap build (https://expeditionportal.com/forum/...2017-ford-f-250-and-spacekap-diablo-8.207675/) and have enjoyed it as a full-timer and this has been my first Winter (Northern Coastal California but in a valley that can get decently cold on occassion and have had some 20 degree record lows). It has been quite reliable with only a couple failures that I attribute to a small amount of water condensation in the fuel tank on one occasion (siphoned empty and refilled, no problem) and probably some soot in the combustion chamber on another (tapped and shook unit quite hard and it restarted without having to actually open it up). My SpaceKap has been insulated reasonably well for what it is, but there are some drafts around doors and bed installation points for reference. I find it uses 0.5 amps @ 12 volts on low and 0.10 L/HR running after initially start up and before end stage purge cycles. That amount of heat on low seems to buy you a ~30 F degree increase (adjust my maxxir roof vent opening to make some crude adjustments and let any excess moisture chimney out) which is very nice for how I like to do things: still use pretty heavy sleeping bags to keep warm but well above freezing so your face doesn't start to hurt and impact sleep quality.
A few extra tips:
-If it going to be below freezing make sure to adjust the mixture to include some pure kerosene (planar manual floating around somewhere had a chart indicating percentage). I also think it is good to run some pure kerosene for maintenance and reliability sake on occassion.
-The portable planar unit has purge cycles to keep the combustion chamber cleaner even if you are running it on low all the time, however, if you are using a standard unit (or a chinese clone probably), you need to run it on high every 12 hours or it will foul up and need to be cleaned.
-Ventilation and safety precautions are not be minimized at all for any and all heating solutions. Unless, you have an amazingly well insulated rig (talking R20 here) with no cold bridging where you can have it sealed up tight and just have a vent cracked and a heater that pretty much only kicks on before you go to bed and in the morning, I would much rather have high quality bedding and let things get a little cooler with very good ventilation/air circulation in such a small space. Even non-lethal amounts of CO can build up in your system and really hurt your health overtime. @john61ct Is absolutely right
All in all, I think Planar (and probably some of the chinese clones) are the best heating options available for most serious rigs nowadays. Electric vehicle battery tech needs to come a long way before mobile electric heat/AC becomes a practical reality.
A few extra tips:
