charlieaarons
So I guess you’re going to air down 285/55s that have a sidewall height of ~6.2”. Whereas 285/70R19.5 and 305/70/19.5, both with enough load capacity to be useful as singles for a 550 type application, have sidewall heights of 7.8” and 8.4” respectively. Admittedly the X.5 wheels (16.5, 17.5, 19.5, 22.5) have crappy bead retention.
You should know that footprint increase with deflation is highly dependent on sidewall height and inversely dependent on wheel diameter, diameter being equal.
Although you stated “no serious offroad”, you rejected 19.5s partially because “can’t be aired down”. BTW Peter of Peter & Margaret in Australia with an Oka has had good results airing down 305/70R19.5s.
But I guess it’s a done deal.
Good luck.
Good luck.
