*SOLD*2008 Lexus GX470 $18,500 Bay Area , CA
*SOLD*
2008 Lexus GX470
VIN: JTJBT20C080163216
$18,500
153k miles, still being driven weekly.
Contra Costa County,CA
Please contact me via DM for any additional information .
Up for sale is my 2008 GX470. Moving on to a new project and I don’t need two vehicles. I purchased the vehicle from Toyota of Marin in 2017.
Tires and wheels: SCS Ray 10’s with KO2’s, 285/70/17 . Spare tire is mounted on a Wilco swing out .
Suspension: Toytech 2.5” body shocks,SPC UCA’s and Differential lowering kit. New LCA’s installed in 2020,BMC. Installed by Steller Offroad in Sacramento,CA . Ride height control was removed, as well as the air bags.
Armor: Metal Tech from hybrid bumper and RCI skid plates for the engine and transmission.
Electrical: Off Grid Engineering Dual Battery Kit. House battery is less than 1 year old. Odyssey G34 starting and G35 house.
Blue Sea fuse block feeds a cigarette lighter plug,dual USB,Voltage and temperature meter in the rear cargo area for running accessories.
Victron MPPT solar charge controller mounted under the hood, I used a trolling motor water resistant plug(female receptacle is mounted to a plate welded to the front bumper). 50w solar panel with male trolling motor plug. I attached rubber coated magnets to the panel to set it on the roof rack or hood when parked and camping.
Baja Designs Amber fog lights mounted to the Metal Tech bumper in place of stock fogs.
Rigid Industries Ignite’s flush mounted in rear bumper as auxiliary back up lights.
Remote start installed by Best Guys in Concord,CA . Two remote start key FOB’s .
Weathertech front and rear passenger floor mats. Stock Lexus carpeted cargo mat in rear cargo area.
Timing belt replaced at 121k miles.
Transmission fluid and filters replaced about 2.5 years ago.
Synthetic oil changes at 5000k miles. Differential and transfer case fluid replaced yearly.
Front wheel bearings and front rotors replaced in 2020.
Cargo area fold down seats are not installed. To reinstall passenger side fold down seat, rear 12v power I installed would need to be relocated. I took the seats out right away to increase the rear cargo area capacity.
Owners manual and one key fob.
Last winter the Secondary Air Injector Pump started throwing a code, no performance issues. I installed the plug and play bypass module cleared the codes. They popped back up occasionally but only when remote starting the vehicle. Vehicle passed smog with no issues after installing the electronic bypass.
I maxed out the photo upload, so they are somewhat out of order.
Ancientsojourners
