Introducing the Eezi-Awn Swift Awning
ThePartyWagon
thanks for the advice! Been following your youtube on the eeziawn products and the vid on how to use the legs was very helpful btw.
Yeah im from the Philippines and I sent eeziawn an email asking for any tips they can give as well. Btw would you know if the sail tracks on the outer side of the rafters fit sidewalls from ARB? Are sailtracks pretty generic in size? Was thinking of trying it out as the enclosure is only available here by special order.
It looks like the ARB sailtrack is probably larger than what you find on the Eezi Awn rafter arms. This is the best photo I can find and it appears to be larger in diameter. Not sure it would work.
Thanks,
shoredreamer
thanks dude! Yeah you’re right. Looks like they’re using the aussie 6mm sailtrack. Eeziawn might be using the 4mm sailtrack for euro standards.
Yeah the sail tracks are different size, ARB to Eezi. For the side wind break on the Swift I used ARB 813207 2M front break. To attach it to the side arms, I drilled 6 snaps into the top of the arm and the corresponding button snap into the fabric. So snap it in 6 spots and you’re done. For the front wind break on the Swift I used the ARB 813413 side break. This one just velcro’s over the round tube. I sold the whole setup last year to a friend. I do miss the easy setup.
Hdj80selosa
Thanks dude! The tension rod in the middle is strong enough to hold the sidewall?
Also can I ask the reason why you sold it? ? I’m kinda frustrated with the lack of sidewall kits on hand for the eeziawn and how its designed but i love it nonetheless
edit: also can i also ask what you did for the water pooling issue on the canvas?
Jollyrogers
I have a Eezi-Awn Swift, and only wanted a couple windbreaks/extensions. I would have bought the Swift awning room, but none in stock at this time, and it costs more than the awning itself. So, I got 1 of each of the ARB front/side awning windbreaks listed above. I removed the welt from the front ARB and replaced it with some plastic welt piping 6/32”. Had my wife sew a seam to make up for the smaller size. Fits the sail rail perfectly now.
The front pole will hold also, but I’d watch how much tension you put on it.
For rain, slightly raise on side and lower the other enough for run off.
TCM
Adventurer, Overland Certified OC0006
I have a Eezi-Awn Swift, and only wanted a couple windbreaks/extensions. I would have bought the Swift awning room, but non in stock I can find, and it costs more than the awning itself. So, I got 1 of each of the ARB front/side awning windbreaks listed above. I removed the welt from the front ARB and replaced it with some plastic welt piping 6/32”. Had my wife sew a seam to make up for the smaller size. Fits the sail rail perfectly now.
I had the same plan to modify awning walls from ARB to fit the Swift. I bought the walls but never got around to modifying them. Glad to know that doing so actually works.
EquiptExpOutfitters
Supporting Sponsor
Do you have any pictures with the modified ARB walls?
Jollyrogers
I am using it right now at a fiddlers convention. Here are pics with the modified ARB “front” that slides into the sail track on the swift, being used to keep shade as the evening sun shifts towards front of truck. Makes a huge difference. I can access both truck doors when setup like this. I can also drop it down, which I do when my GSD is with me in campgrounds to minimize her stress and barking. The Swift front uses the ARB “side” and doesn’t need to be modified.
