2007 Supercharged 5-speed AT FJ Cruiser – $22,500
EMWDROSS
118,xxx original miles, original owner, all maintenance records, clean title and emissions in hand
A well-loved, well-maintained, well-built, and proven rig that will take you just about anywhere you want to go and is ready for thousands of miles before you have to do anything to it. Dates in () are the year of install or replacement.
ENGINE
  • 4.0 liter V6
  • TRD Supercharger (~300bhp, ~330ftlbs torque)(2008)
  • URD 2.825” SuperGrip Pulley (+1.5 – 2.0 PSI) (2018)
  • Iridium spark plugs (2018)
  • aFe Cold Air Intake with Pro Dry S filter (2018)
  • Safari Snorkel (2007)
  • Off-Grid Engineering Dual Battery System and Bosch batteries (2018)
  • OEM fuel pump (2017)
  • Custom Magnaflow high clearance exhaust (2018)
TRANSMISSION
  • 5-speed Automatic
  • OEM rear e-locker
  • ATRAC (hacked to run with rear locker)
  • Rear axle assembly upgraded from OEM 8” to OEM 8.2” (2018)
  • 4.56 Nitro gears (2018)
  • CVJ remanufactured OEM CV axles (2018)
  • OEM shift box replaced (2020)
  • Religious severe duty maintenance schedule
SAFETY
  • Driver & passenger front & side airbags, and side curtain airbags
  • Traction Control (TRAC), Anti-lock Brakes (ABS), Brake Assist (BA), Electronic Brake Force Distribution (EBD), Vehicle Skid Control (VSC)
  • Brake pads replaced in 2017 (front rotors at 10/32, rear at 8/32, e-brake adjusted 2018)
  • Airbag spiral cable clock spring replaced (2018)
SUSPENSION
  • OEM lower control arms and ball joints (2018)
  • OEM steering rack (2018)
  • OEM rear sway bar and links (2018)
  • Toytec Boss 2.5 front coilovers (2018)
  • Icon Overlander rear springs + Icon 2.0 shocks (2018)
  • Rokmen Off Road heavy duty adjustable panhard bar (2018)
  • Rokmen Off Road heavy duty adjustable lower control arms (2018)
  • Toytec adjustable aluminum rear upper control arms (2018)
  • Toytec rear aluminum 2” bumpstops (2018)
  • Stainless steel extended rear brake lines (2018)
  • Total Chaos upper control arms (2018)
  • Total Chaos welded spindle gussets (sway bar removed) (2018)
ARMOR
  • ARB Deluxe Bull Bar with welded shackle mounts, fog and off-road lights, Superwinch 12,500lb winch with 3/8” synthetic line (bumper 2007, winch 2018)
  • BudBuilt front, engine, transfer case 3/16” steel skid plates (2007)
  • BudBuilt/ARB 1/8” filler plate (2018)
  • RCI sliders with kickout and tread plate (2020)
  • RCI metalworks lower link skids (2018)
  • Expedition One trail series rear bumper with smooth motion tire carrier with switched reverse lights and undercarriage LED landing lights, rear parking sensors (2017)
  • ICON stainless steel lower shock shin guards (2018)
TIRES
  • 255/85R16 (33/10.50) Toyo Mud-Terrain tires (4) with 90% tread life on Wheelers Off-Road 16” steel wheels (plus 2 spares: BFG KM and BFG KM2)
OTHER
  • OEM dash gauge cluster with time/temp/compass/inclinometer
  • OEM 9-speaker stereo with subwoofer, CD player, and AUX input with dual-input switch for ham radio or other input
  • OEM rear cargo 100W/400W 115V inverter
  • OEM driver & passenger side sun-visors
  • OEM arm rests
  • InSain Fabrication rear door molle panel
  • InSain Fabrication rear quarter window molle panel
  • InSain Fabrication rear roof molle panel
  • InSain Fabrication passenger dash mole panels
  • Radio Shack CB Radio with Weather channel/alert mounted to headliner with 4’ Firestik on rear door Bandi mount (2006)
  • Dash-mounted ScanGauge linked to OBDII plug (2007)
  • RAM mount with X-grip for iPad or similar (2018)
  • Aftermarket 12V plug triple plug in passenger footwell
  • Aftermarket driver and passenger heated seats with in dash switches (2007)
  • ViAir 400C on-board air compressor wired/mounted in the cargo compartment (plumbed for an external tank behind the rear bumper if you want to add one) (2007)
  • ARB full-length roof rack with mesh floor (2007)
  • Hella sharptone twin horns (2018)
  • Rear seat delete with leveled custom tie-down platform and storage (OEM rear seats included)
  • Maintenance and parts records from day of sale to present
NOT INCLUDED IN SALE
  • Kenwood D710GA dual band APRS ham radio with roof-mounted antenna (if you’re a ham operator and want this radio, we can talk)
  • Expedition One combo PullPal & Hi Lift mount
  • Colorado 4x4 Rescue & Recovery fairing
BLEMISHES
  • Passenger rear clamshell door is dented, but fully functional
  • Normal wear and tear paint chips here and there
  • A few minor body dings
  • Typical minor frame rust for a 14-year-old Colorado car
zgfiredude
This is owned by a good long-time friend of mine. I know this vehicle and it's history quite well and could not recommend it and it's owner any more! This FJ has had very meticulous maintenance it's whole life, and is good to go. It has been used as intended, but any and all issues that have ever come up were handled asap.
If you are looking for an FJ, you really should consider this one! Don't let the low post count cloud your judgement.
extremer
I have an 08 FJ w/ supercharger since new w/ 180k miles and have always got right around 15mpg whether I'm city or freeway...the supercharger is worth every penny IMO
EMWDROSS
Was is the rpm @ 80mph highway speed?
What is fuel capacity and mpg?
RPM at 80mph is @3,000
19 gallon tank and I get 15mpg consistently
Even fully loaded its able to maintain speed in 4th gear up and over Floyd Hill, Eisenhower, and Vail Pass
EMWDROSS
If you're looking for extended range, Man a Fre offers a nice expedition aux fuel tank that tucks behind the rear axle and doubles fuel capacity:
Papaco
agreed that supercharged is the way to go, that is how my current GMC yukon xl is setup...
as for RPM, 3000rpm is really high... at least in the v8 world I live in and am used to... i cant imagine doing a long trip at that rpm...do you find that high?
btw, that is a nice rig and clearly you paid attention to many details...
EMWDROSS
Most of the driving I've done in this rig is in the mountains, so sustained speeds of 75+mph is rare, more like 65, however on the occasion I have made longer trips, the V6 is pretty comfortable at that rpm range. Also keep in mind it has been geared to 4.56 (OEM is 3.73) and only on 33s. I've ended up liking the additional engine power and especially engine braking with that gearing, tire size and engine revs for mountain and off road driving. Bumping up to 35s would drop the revs, but have never felt the need to go that big.
And thank you! I've really enjoyed building and using this rig through its many iterations over the last 15 years. Where it stands now there is very little I would do to improve it.
