2013 Tacoma fully built for overlanding and daily driving
osinrider04
Selling my 2013 Toyota Tacoma TRD Offroad so that my family and I can move into a Class B RV. We don’t do as much off-grid camping with a 2.5 year old so my rig is up for sale. I bought this truck off ExpeditionPortal about 4 years ago and have substantially changed the vehicle since then. True mid-travel suspension, 3 way adjustable coilovers, alu cab camper shell, hardshell RTT, and more. This truck can truly support you offgrid for as long as your food and water can sustain you, or it can be driven as a daily driver because of the considerable amount of planning and execution of parts. Inside the camper shell I have wired up charging stations on both sides of the full-length doors so you can charge electronics. Quick release hose adapter has been installed into the decked system for showering or rinsing off. Front bumper has a quick release air hose adapter for the ARB compressor to air up after wheeling. Hardshell RTT opens in seconds for a great sleeping arrangement. Solar charges both the starting battery and aux battery with ease. The camper shell was swapped out for Alu Cab’s to support the weight on a hardshell tent plus humans. Most people run the fiberglass shells without problems but I didn’t want to risk anything. The tent only has about 10 total nights in it.
The Good: Most of the major upgrades have been done within the last 12 months. This includes exhaust, suspension, tires, tent, camper shell, fridge, onboard water, drawer system, big brake kit (100 miles), and injectors/spark plugs. Tires only have 10k miles on them. There should not be anything needed mechanically nor overland-based.
The Still-Needed: Rock sliders are showing rust. They need to be stripped and re-painted. The onboard water system was installed last week and has not been plumbed yet. The water pump and all electrical controls are installed. Just need to run the pex plumbing from the water tank to the water pump.
The truck has 140,xxx miles currently with absolutely no issues.
Dirt King upper and lower control arms, mid travel kit, greasable ball joints
Dobinson’s MRR 3 way adjustable coil over suspension
Dobinson’s 800 lbs constant load rear leaf spring (fully greasable shackle bolts)
Yukon 4.88 gears installed by East Coast Gear Supply
Alu Cab canopy camper with custom turn/reverse/brake lights installed by OK4WD
Roofnest Falcon XL RTT
Custom 18 gallon onboard water tank mounted in spare tire area with shurflo pump
2 100 watt renogy flexible solar panels mounted to RTT
2 deep cell Odyssey batteries mounted under the hood with charge controller
National Luna battery monitor and control system
Decked drawer system
Stop Tech 6 piston big brake kit
Custom full stainless steel exhaust system
Custom rear dual spare tire rear bumper from Brute Force Fab
Alu Cab aluminum table mounted to ceiling of camper shell
ARB Front Bumper with Warn 8000 lb winch
ARB 63 qt Fridge Freezer
Alu Cab tilting fridge slide
ARB On board air compressor
ARB 2500x2500 awning with full mosquito room enclosure
ARB safari Snorkel
DFG Offroad shower enclosure, never used
RCI front skid plate
RCI transmission skid plate
RCI transfer case skid plate
RCI fuel tank skid plate
RCI rear differential skid plate
RCI rock sliders with top tread plate
BFG KO2 only 10k miles on them (6 in total)
Method Double Standard wheels (total of 6)
Brand new driver and passenger steering knuckles OEM
Bed Rug cargo carpet
Lifetime Led 195 watt Lights spot
6 Vision X rock lights
Bird Dog industries iPad and phone mount
Cobra CB with custom quick detach antenna
Husky floor liners
Price is $40,000 obo
osinrider04
Here are some more photos. I have tons more of the build so PM me for anything specific.
osinrider04
Here are a few of the exhaust that was just installed. Full stainless steel with high floor resonators. Completely street legal, very quiet.
hudd07
Thanks! A ton of time went into the build, but things change when you have a kid [apparently] so we’re looking for the next rig that suits us.
Trust me I know. Wife due with second. I’m looking at selling some toys not because I have to but just simplify life while 2nd kid makes it more complex. Bought a triple locked LC 100 with Roof Top Tent and debating selling because I know won’t use for a couple years with new infant.
Good luck with sale.
Hodor
This is a sweet rig but I can't rationalize a short bed for my useage ? Otherwise it's exactly what I want to do
osinrider04
I went with a short bed build to keep it as nimble as possible in offroad situations. I’m 6’4 so even a long bed I would never be able to sleep in anyways. What would you be doing with it that you need a long bed?
Hodor
Living and working out of
Carrizo
Hey there! A few questions:
- Did ECGS do the needle bearing swap during the regear?
- Was the catalytic converter tampered with at all with the new exhaust?
osinrider04
I’m not positive if they replaced the needle bearing. I would assume they did. I can call and confirm if needed.
Nope—the cats and all O2 sensors are intact. Exhaust is fully legal
osinrider04
I will also consider a trade for a stock'ish SUV of some kind. I need to get a daily driver so if anyone is looking to make the switch let me know!
dhuss
